Show me a good center speaker
anhchungdoan
anhchungdoan Posts: 760
edited February 2010 in Speakers
I am looking to upgrading my Mirage surround speaker 5.1 sytsem. I just feel the Onkyo 876 can sound better with another brand. It's the synergy thing between amp and speakers.
While I am very pleased with my Pio SC05 and 6 of Def Tech SM450s and the CLR2002, I do want a diiferent brand name and different sound for my Onkyo 876. Nothing is wrong with the Mirage LFX system . I am searching for a center speaker that can sound at least as good as and as realistic as the Def TecH CLR2002 for my Onkyo system.
Onkyo oner can chime in anytime. I do not want to add any additional external amp, so it has to be 8hm and 88/ 91db efficiency. Monitors and center speaker only, no floor standing please.
Post edited by anhchungdoan on
  • danz1906
    danz1906 Posts: 5,144
    Polk RTiA3 speakers and RTiA6 center speaker:)
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • ViperZ
    ViperZ Posts: 2,046
    It all depends on your price range... and IMHO the center should perfectly match the bookshelves.
    I just picked my new bookshelves (B&W CDM1), and these are the ones I was looking at:
    * NHT 1.5 with NHT AudioCenter-2, but AC-2 is very hard to find, so you may try AC-1
    * Paradigm Studio 20s or 40s (v2 or v3) with matching center (CC-470 I think),
    * Polk LSi9s with LSiC, (these are 4 Ohm)
    * B&W 685/686 with HTM61,
    * Quad 12L2 with L2 centre,
    And obviously B&W CDM1 with CDM-C center (or CDM-1NT with CDM-CNT).
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • anhchungdoan
    I have 5.1 Polk RT15I for my kids system so I look for something difference this time for MOI. The Def TEch CLr 2002 is so good and I need to have some center at least that good.
    Anyone hear the ML low-end H/TMotion package? Small room 14X16, so my option is limited to momitors system . THe Motion looks cheap with push and snap in speaker connections.
    Tony M Posts: 11,728
    I think I've read that Polk audio and Onkyo match up well.
    I've owned alot of center channels and they all have their own sounds. The center should definately match your L/R speakers in timbre. You can get lucky and mis match brands and get close and that's fine with me too.
    Good luck with your search.
  • anhchungdoan
    10/4. I know about the timbre matching but I want to start to upgrade all my 5 Mirage speaker system and I want to built the 5.1 ot 7.1 speaker system around the center speaker if I can find a center that's better than my Def Tech CLR 2002.
    love to have all the LSi series but they are 4 ohm abd 88db which mean I have to get another multi-amp.
  • superjunior
    superjunior Posts: 1,632
    danz1906 wrote: »
    polk rtia3 speakers and rtia6 center speaker:)
    +1 ^
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • anhchungdoan
    Allright Polk fans, I will pay Frys' a visit to listen to the RTIa series with their Onkyo 876. Spec and build quality look fine. Thank you.
