Rm6750
Wojo
Looking for some help from other polk users. I just picked up the rm6750 and will be connecting it to a Sony STR-DH800 receiver. There is no specific way mentioned in the instructions that suggests a better or best sound for this system. Any suggestions on wiring all of this is greatly appreciated. I also picked up 100' of monster cable from Radio Shack for $45.00 so that's what I plan to use for the wire.
Post edited by Wojo on
Its not too hard, just hook up the speakers with the speaker wire, grab an rca cable for the subwoofer and see how she sounds. If theres a way to adjust the speaker size and crossover, set the satellite speakers to small or 120hz crossover cutoff. The sub does a good job of handling the lows and the satellite speakers sound pretty good for the mids and highs. All in all i was happy with my setup, however i've upgraded the front speakers and subwoofer since. I still run the rear speakers in my setup and they work great. I bought the speaker stands made by polk for the rears, it put them at the perfect height for my living room setup. The manual does a good job of explaining how to set things up based on the various connection methods, just use the one that fits your AVR.
