garard tt
rcrook317
rcrook317 Posts: 280
edited February 2010 in Electronics
whats everybodys opinion regarding these tts?
i believe its a model 70 or model 770.
waiting on response from seller mite pick it up to give vinyl a try.
fronts=rti12s(cherry)
center=csi3(cherry)
sub=psw125(cherry)
emotiva xpa-2
harmon kardon 354
sony cdp
ipod 8gb
audioquest diamondback 1m
"Maesto" straightwire cables
pangea ac-9
playstation3/120gb=blu-ray/media server
monitor=lg 55inch lcd(1080p)
TT Set-up=Pro-Ject RM 1.3
Kenwood Phono
bren1 Clamp
Herbies Slipmat
"It doesnt mean that much to me,to mean that much to you"
Post edited by rcrook317 on
  • Polkersince85
    Polkersince85 Posts: 2,883
    If you can get it for less than 10 bucks, give it a try. Hope this helps.
  • rcrook317
    so its pretty much junk huh?
    ill pass.
    just interested in vinyl after hearing couple tts in local shop.dont want to spend a ton since i have very little epeirence in vinyl
    center=csi3(cherry)
    sub=psw125(cherry)
    emotiva xpa-2
    harmon kardon 354
    sony cdp
    ipod 8gb
    pangea ac-9
    Kenwood Phono
    bren1 Clamp
    Herbies Slipmat
  • Polkersince85
    You will be better off finding a more capable table such as a Technics DD or an older belt drive with a higher quality tonearm. Buying a flimsy table and thinking vinyl sounds like crap is not where it is at.
    To get good sound, bring you wallet. Go to vinylengine.com, sign up and browse around the library there. Use the search feature on this forum for tons of info.
  • rcrook317
    yeah been checking vinyl engine and on here.as i said before ive heard some good tts but dont wanna throw 3-500 on a tt when im totally new to it.
    i do like the look of the pro-ject series just on the fence about spending 350-400 right out the gate when i only got like 4-5 lps and zero expiernce on the subject
    center=csi3(cherry)
    sub=psw125(cherry)
    emotiva xpa-2
    harmon kardon 354
    sony cdp
    ipod 8gb
    pangea ac-9
    Kenwood Phono
    bren1 Clamp
    Herbies Slipmat
