What are the benefits of speakers within the same series?
Reimer
Reimer Posts: 53
edited February 2010 in Speakers
Can someone please tell me what the benefits are of staying within the same series?
I have the RTi10's as my front speakers and everyone has told me to try and get the CSi5 as my centre channel and if not then the CSi6.
I have recently been offerd a pretty good price on the LSiC but was hesitant to buy it because due to it being from a different series.
Can someone please tell me the advantages and disadvantages of switching between series? Thanks,
Post edited by Reimer on
  • concealer404
    concealer404 Posts: 7,440
    Matched tweeters... :)
  • bluecomet
    bluecomet Posts: 1,118
    Do not switch to the Lsi series unless you get Lsi mains for it. They are 4 ohm speakers. Go with the CSi6 and enjoy your HT. I have the Lsi series and you will need external amps to run them properly. You will be getting into big money. To me it was worth it but for the casual listener it may prove to be needless expense.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • DollarDave
    DollarDave Posts: 2,575
    The tonal qualities (timbre) are different from series to series.
    And, the RTi series are 8 ohm and the LSi series are 4 ohm speakers.
    I would keep at least your front soundstage within a series, most say the rears are not as important and I have mixed those in the past with acceptable results.
  • Knucklehead
    Knucklehead Posts: 3,602
    Reimer wrote: »
    For the front 3 to be "timbre" matched tweeters "should" match, surrounds are not AS important. If you ask Polk CS, they will tell you as they have told me that MOST of their HT speaker lines are designed to be used together.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Reimer
    Reimer Posts: 53
    Awesome thanks for the feedback. I never understood why some people were so into home theatres. I just wanted something that sounds great. But this all makes sense. I will definitely stick to the RTi series. I was also planning on Rti speakers anyhow for the rears anyhow.
  • ViperZ
    ViperZ Posts: 2,046
    I don't think there is such thing as CSi6. There is CSi5 and CSiA6. For your towers, CSi5 would be a matching center.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • Reimer
    Reimer Posts: 53
    ViperZ wrote: »
    That's what I am talking about. I see som many people on here type the letters sometimes and then don't type them other tiems so I jsut went with CSi6.
    Yes I would prefer to go with the CSi5 over the A6 but the main issue is that they don't make the CSi5 anymore and it is harder to find so I might have to settle with the A6.
  • Willow
    Willow Posts: 11,233
    Reimer wrote: »
    That would work.
  • ViperZ
    ViperZ Posts: 2,046
    It depends how well the speakers are sonically/timbre matched.
    Talking about CSi5 - somebody just posted one in the FM, CHEAP:
    http://www.polkaudio.com/forums/showthread.php?t=96126 (and edit again - you already saw it, lol)
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • Reimer
    Reimer Posts: 53
    ViperZ wrote: »
    From what I have heard from others on here the A4 and the A6 series replaced the old RTi. So I would assme that they match up pretty decently.
