What is the crossover freq of the mm6501
priussound
Does anyone know the spec of the tweeter. There are numerous reflections for the mids in the forward front door position. I may biamp and want to set the crossovers as low as possible to get some of the midrange to the dash position where I will place my tweeters.
I'll be using db651 or mm651 as fill in the lower part of my front doors.
The tweeters dash location is about 18" further away from my then the door locations. The rear door location is a little closer than the front.
Thanks for your response.
Post edited by priussound on
