Jbl 4312
curved
I'm looking to do a mod on my JBL's and am looking for suggestions with caps. I'm still debating if I should go with Sonicaps or spend the extra $ and go with something better for the highs.
2x .01uF
1x 3uF
1x 8uF
Will be going with Mills resistors
2x 8ohm
I will be using my 545 to power them and will be looking to add a nice pre to the mix.
Suggestions for caps and/or pre's?
2x .01uF
1x 3uF
1x 8uF
2x 8ohm
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
Pre - Nak CA-5
BR - LG BD390
Post edited by curved on
Excellent...Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
**Dayton and Sonicap Caps with Mills Resistors** -
Look up Parts Express. Many cap options available by Auri, Sonic, Solen and others.
http://www.parts-express.com/wizards/searchResults.cfm?FTR=caps&search_type=main&WebPage_ID=3&searchFilter=caps&x=0&y=0
Adcom preamps are not so good, except maybe the 750. Look to NAD, Rotel, and Emotiva among the better SS budget pre's, but you can do better. The Dynaco Pas3 is a very nice vintage tube pre, but the vintage Conrad Johnson tube pre's are better.
