New Surround
nicnaim
nicnaim Posts: 1
OK, so I got this new system an I want to hook it up but I ain't sure how to do it. It was an open box with no instructions. It has a DVD unit an some small speakers, a big speaker an another thing that is bigger with a hole in it. I figured out that the speakers hook up to the back of the DVD unit but I don't understand what C, FL, FR, RL, RR and SW stand for.
  • Knucklehead
    Knucklehead Posts: 3,602
    edited February 2010
    C- center channel
    FL- Front Left
    FR- Front right
    RL- Rear left
    RR- Rear right
    SW- Subwoofer
    Sounds like a HTIB (home theater in a box). Not sure if you have speaker wire but the main unit should have speaker outputs in the back labled as I described above. Just match up your speakers to the appropriate connections. The sub is the largest speaker with the port. The center may look a little different than the other 4.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
    One more thing, you hook up the speakers to your receiver,not the dvd player.unless the receiver and dvd player are one unit of coarse. How about posting a model number,what brand it is, what gear you have,and we can better serve you.
  • keeneyrm01
    keeneyrm01 Posts: 80
    if you google the name and model number you can probably fine an online manual, that will help you a lot.
    HT basement room:
    TV- 42in Panasonic S1 Plasma
    A/V Receiver- Onkyo NR807
    Blu-Ray- 80GB Sony PS3
    Power Supply- Monster HTS-1600
    5 Disc Sony CD/DVD Changer
    Time Warner HD Cable Box
    Speakers:
    Front- Polk RTi A3
    Center- Polk CSi3
    Side Surround- Polk RTi4
    Back Surround- Polk RM6750
    Sub- Outlaw Audio LFM-1 EX
    Bedroom:
    32in Visio LCD, Sony STR-DE685 AVR, MTX Monitor 12, Sony 5 disc DVD changer
