Carpet Spikes.....
dl090465
does anyone know where to get a set that will fit both the RT100i and RT2000p ????
Thanks....
Thanks....
Room 1:
ONKYO TX-SR608
Polk Complete RT 5000 System
Polk RT3000p's Front
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk RT2000's Front Someone Please Sell Me Some RT3000 so I can have a second RT5000 setup !!!!
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear
Post edited by dl090465 on
https://myesound.com/Points_n_pads.html
Best in the business. Tell Grant that you are a member of Club Polk then tell him what speakers you need the spike for and he'll hook you up. -
Thank you !!!Room 1:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear -
Are these what you're looking for? Post #8 shows a good photo of them. I'm not sure if Myesound has them but YNK. http://www.polkaudio.com/forums/showthread.php?t=85724SDA SRS 2.3TL's
SDA 2B TL's -
The 1000s already have spikes in them. Take the rubber surround of and the spikes are exposed. Not sure about the 2000's.
i will try that when i get home, thanks for all the suggestions...i found one website that sells them, just need to find what thread ours have...Room 1:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear -
I have RT2000Ps and they already have spikes on them.
Someone here should know that. PM Dorokusai or F1nut, they should be able to tell you the thread size. -
hearingimpared wrote: »I have RT2000Ps and they already have spikes on them.
are you just pulling off the rubber feet???Room 1:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear -
The fellow I purchased them from had already removed them. I had a hell of a time getting them out of the box without the need for stiches.;):D -
hearingimpared wrote: »The fellow I purchased them from had already removed them. I had a hell of a time getting them out of the box without the need for stiches.;):D
OUCH........Maybe I should leave the rubber feet on??? I read a couple of posts that say tey sound better with spikes on top of carpet....Room 1:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear -
Move the speakers into place then remove the rubber feet. If you need to move or adjust them then you have to learn the speaker waltz.
Spiked speakers on carpet sounds leaps and bounds better than just setting them on the carpet. -
hearingimpared wrote: »Move the speakers into place then remove the rubber feet. If you need to move or adjust them then you have to learn the speaker waltz.
Thank you, that it what I thought....hopefully I won't get "Bloody" doing this...LOL...Room 1:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear -
Spike them and don't look back, For me this is the best tweek for speakers.Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
My RT2000's are now spiked !!! I never thought the rubberpart just slides off. I had RT1000p's for 10 years and didn't think about it...
Now i got to remove the rubber feet on my RT100i's, thanks everyone for the help today !!!Room 1:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear
