RTi A1 Crossover damage
randysweb
I have an old Denon AVR 3801 it seems as though it man-handled one of my Rti A1 crossovers. R1 and C1 are smoked. C1 is a 9.1 uF 50 V NP capacitor, and R1 is a 5W 3ohm J ceramic wire wound resistor. I can not find either of these components and was hoping someone out there could help me out. I would even consider buying the entire crossover if a replacement is available. Can I use substitute components? Not an expert here, thanks in advance to anyone that can help.
RS
RS
You should be able to call Polk for a replacement. You can also upgrade the caps but you'll have to do both speakers.
