2 subs?
rcrook317
rcrook317 Posts: 280
got a hypothetical question....my hk 354 has only 1 sub out.if you plan to put two matching subs on either side of the room is there any way to run two separate subs thru 1 avr and a amp?
thanks
fronts=rti12s(cherry)
center=csi3(cherry)
sub=psw125(cherry)
emotiva xpa-2
harmon kardon 354
sony cdp
ipod 8gb
audioquest diamondback 1m
"Maesto" straightwire cables
pangea ac-9
playstation3/120gb=blu-ray/media server
monitor=lg 55inch lcd(1080p)
TT Set-up=Pro-Ject RM 1.3
Kenwood Phono
bren1 Clamp
Herbies Slipmat
"It doesnt mean that much to me,to mean that much to you"
Post edited by rcrook317 on
  • concealer404
    concealer404 Posts: 7,440
    edited January 2010
    Y-cable.
    1 female to 2 males.
  • Knucklehead
    Knucklehead Posts: 3,602
    edited January 2010
    I will say its a lot of hands and knees work to get 2 subs to sound good...damn i think ive seen every square inch of my carpet :)
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • halo71
    halo71 Posts: 4,632
    edited January 2010
    Y-cable.
    Isn't that Y cable 1 male to 2 females?
    --Gary--
  • hikarate
    hikarate Posts: 4
    edited January 2010
    I have a question on this. My sub has speaker binding posts for Left and Right speakers to pass through it. The manual says this is for cases where the receiver doesn't have RCA sub out. Concerning purchasing another sub:
    1. Is it possible to run the Left channel through Sub1 and Right Channel through Sub2 and set the Fronts to Large? Basically making each Sub and Bookshelf work as a Tower.
    2. Would there be any benefit to doing this over using the RCA Splitter?
    I assume the crossover setting on the sub will split the signal between the sub and bookshelf. Also assuming the receiver will send all the bass info to the Front speakers set to Large since the Sub out is not being used and all other speakers are set to small. So I got a lot of assumptions going on, and that usually not good. Thanks for any replies, this is just something I was curious about.
  • halo71
    halo71 Posts: 4,632
    edited January 2010
    1. Yes that is very possible.
    2. Don't think there are real benefits. I have always heard using the RCA connections sounds better. Although I have never personally tested the two. I have my sub running from the sub out, to a Y cable then L/R into the sub.
    --Gary--
  • concealer404
    edited February 2010
    halo71 wrote: »
    Yeah, that. :p My bad.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    This is very true, but it is possible with the advice above.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
