Question on SDA 1C connector cable
Hypnotoad
I have the blade and pin type connector cable for the SDA 1C's.
Where can I get the actual plugs at the end of the umbilical cable as mine is not working and want to make another one?
Will the 2 pin Din type plugs work as they are the only ones I have seen that are similar?
At the moment I am just using speaker wire jammed in the holes.
Any help would be appreciated.
ProJect Perspective II Turntable & Benz Micro Ace
ProJect Tube Box II & Philips/Amperex tubes
Luxman L-430 Integrated
Polk SDA 1C's
Polk SDA 1C's
Post edited by Hypnotoad on
if you are not afraid of doing things yourself, you can use speaker wire binding posts, or as you said, most any connector if you are willing to modify the speaker and interconnect cable to match.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
There are several ways you can.
As suggested above
Contact Ben here at CP who makes them
Make your own by buying an RCA connector and soldering your cable of choice or buy a premade RCA cable. In both cases you will have to remove the outer ring of the RCA connector.Speakers: SDA-1C (most all the goodies)
Only one of the wires is actually transmitting a signal in the 1C so you can replace the original with a single terminal. It has been discussed at length on this forum. Just do a search and you will find most, if not all, your answers.I have the blade and pin type connector cable for the SDA 1C's.
Any help would be appreciated.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
If you have soldering skills and aren't afraid to modify the SDA cable socket, this thread will help you out.
http://www.polkaudio.com/forums/showthread.php?t=30467
