AVR Sony STR DA 2400 ES with Polk Audio RTI A5
My cuestion: could be fine my AVR with rti a5?
AVR specifications:
Out put power Estereo
(8 ohm 20 Hz 20 kHz, THD 0,09%):
100 W + 100 W
Salida de Potencia Referencial en Modo Estéreo
(4 ohm 20 Hz 20 kHz, THD 0,15%):
85 W + 85 W
Salida de Potencia Referencial (8 ohm 1 kHz,
THD 0,7%)
FRONT2): 110 W + 110 W
CENTER2): 110 W
SURROUND2): 110 W + 110 W
SUR BACK2): 110 W + 110 W
Salida de Potencia Referencial (4 ohm 1 kHz,
THD 0,7%)
FRONT2): 100 W + 100 W
CENTER2): 100 W
SURROUND2): 100 W + 100 W
SUR BACK2): 100 W + 100 W
Thanks.
AVR specifications:
100 W + 100 W
85 W + 85 W
THD 0,7%)
CENTER2): 110 W
THD 0,7%)
CENTER2): 100 W
Thanks.
Post edited by Fran400d on
The Sony will drive the A5 with no problem.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
You will not have any issues with that sony receiver and the A5's. The A5's are pretty easy to drive. I am using a 50 wpc HK with mine and they sound great.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
No, no, no.. Those AVR ratings suck.. use your pre-outs and get an emotiva xpa-3. That's real power.
Once you go beyond two channels, those Sony's AVR wattage's drop like dodo. 100wpc to 35wpc. -
Those power rating figures are not all channels driven, its just per channel rating, just google bench test report on the model and you will know the all channel actual measured output.
