Banana plugs question.
Dabutcher
Dabutcher Posts: 2,597
edited January 2010 in Speakers
I have a 7.1 HT system and I bought good quality 14 guage speaker wire and was considering banana plugs. I just found a good price of 97 cents a pair on fatwallet.com. Do I need seven pairs or do I need 14 pairs? Do they connect to speakers and to AV receiver or just one of them? Thanks,Newbee,Darryl
Post edited by Dabutcher on
  • packetjones
    packetjones Posts: 1,059
    edited January 2010
    The number of bananas that you need depend on how you want to set it up. You can have them only at the AVR or at both the AVR and the speakers.
    AVR/speaker only - 7 pairs
    Both AVR and Speakers - 14 pairs
    I have then on both the speakers and the AVR my self.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • john22614
    john22614 Posts: 214
    edited January 2010
    If you're going to do both ends of all connectors you will need seven 4 packs or 14 2 packs. That's if you don't bi wire, of course. And now class, for our next math problem....just kidding. They connect on most new receivers and speakers. Very convenient when you do any disconnecting.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Monitor Radius 180 surrounds
    Audiosource Stereo Amp for surrounds
    Denon 2910 Universal DVD/SACD Player
    Comcast DVR
    Pioneer Elite 42" Plasma 940 HD
    Harmony Universal Remote
    Blue Jeans interconnects and biwires
    Itunes Air Express
  • grimmace19
    grimmace19 Posts: 1,429
    edited January 2010
    Your question has already been answered however, I really enjoyed my banana plugs from monoprice. About 2 bucks per pair. They fit in great to my yamaha avr and monitor 70's however after buying new cables I moved them into the bedroom on an onkyo with old R50's... not a tight connection at all. They work, but are pretty loose.
  • Dabutcher
    edited January 2010
    Thank you all for your help. I see doing a keyword search that this question has been answered before. Peace, Darryl
  • 98Badger
    98Badger Posts: 317
    edited January 2010
    I use the locking GLS banana plugs. They work very well and I like the secure connection. I picked up a 10 pack from speakerepair.com a while back for under $20 when they were on sale. The drawback to the locking version is that they stick out a little farther than non-locking versions.
  • motobman
    motobman Posts: 32
    edited January 2010
    I use 16 banana plugs and they are the monster ones that you screw in. Takes alot of time and these are only for the front speakers mind you, but well worth it. If you need o unhook for any reason, simply pull them out. They all have a secure connection and plug directly into the back of the receiver as well. Good stuff.
