bi wiring or not
lriker
lriker Posts: 64
edited January 2010 in Speakers
I have a set of monitor 30s as my rears and a denon 1610 as my receiver. I am trying to decide if bi wiring the monitor 30s would make much of a difference in sound. Any thoughts?
Post edited by lriker on
  • RyanJoz
    RyanJoz Posts: 116
    edited January 2010
    Do a search. This question has been asked many times. Most people will say get one good set of wires and replace the jumpers with a short piece of the same wire. Bi-wiring only moves the jumper to the back of the receiver instead of being at the back of the speaker. I would look into Signal Cable if I were you.
    Ryan Jozwiak
    "Because music was meant to be felt and heard"
    polkaudio RTiA9
    polkaudio RT35i
    polkaudio PSW 404
    HK 3370
    HK FL8380
    HK DVD 22
    Adcom GFA 5500
    Samsung 40" LCD 120 Hz
  • Justin30
    Justin30 Posts: 10
    edited January 2010
    I tried to bi wire my Monitor 60 speakers. I really did not like the sound. I had extra speaker wire, so it did not cost me anything. I would not buy extra speaker wire to do it but if you have extra wire and it is no cost then I think it is worth a try. You might like the sound. Make sure that you cut the wires the same length.
    I noticed the sound had a more muddy sound and was not worth the trouble. I achieved more bass out of the speaker but also lost some of the mids.
  • Quality321
    Quality321 Posts: 18
    edited January 2010
    I dont think it will add any benefit if you bi-wire because these are rear speakers and they dont deliver much, If they where the mine fronts you would hear a difference... You should give it a try and determine for your self.... Enjoy!!!!
    Polks All The Way
    Fronts RT55i
    Front Presence RT35i
    Center CSi40
    Side Channels FXi50
    Rears RT55i
    Rear Presence RT15i
    Bottom Line, Greatness and Fun....
  • ben62670
    ben62670 Posts: 15,969
    edited January 2010
    Not worth it.
    Ben
    treitz3 Posts: 19,992
    edited January 2010
    Minor, if any change at all. Save your $$$ for other things.
    Welcome to the forum.
