HT Amp help!?!?
Samuel Aldrich
Well here is my situation, I have an Onkyo TX-SR805 with 130 WPC and Monitor 60s and a CS2 center channel. I plan on buying the RTi12s for my fronts and using Monitor 60s as the rears.
The problem is my Onkyo 805 doesn't push my Monitors very well at all. I tried messing with the phase and it doesn't help. The highs are awesome but it dosen't really push the 3- 5 1/2 in woofers. Is there a way to use an external amp in place of the front two channels? What are some good brands?
I really need something with more power to push them and if I get those RTi12s, then I definately need more power. There are so many brands with over-inflated power ratings that I don't know what I should get.
Then I thought well maybe it is my receiver, well I bought it off Amazon from a Milo Electronics (not an authorized Onkyo Dealer which means no warranty whatsoever) and took it in to be check out. Well 256 dollars later the resistors where changed per a service bulletin but nothing was wrong with it.
I am at a loss why they are being pushed... I have spent way too much trying to get them pushed already. I hooked up my old box set Onkyo receiver which pushes 100 WPC and they woke up lots with mid and lower base. I am absolutely puzzled at why my super awesome 130 WPC aren't pushing them.
The highs sound amazing but very little mids. I just figured that an amp would work but I am lost when it comes to that.
I was looking at Pyle Pro amps but they seem fishy, 2000 watts for 200 bucks? Onkyo sells amps that are 100 watts for like 500 bucks. . . What is the deal with that?
Me thinks there is something wrong with that receiver to not push those 60's at all.....or a connection. Set them to small, xover at 80 (maybe run your autosetup)and recheck...My lowly PIONEER 1017 w/110watts pushed my rti8's (but they sound much better with the an amp). Hey good luck55 Samsung 7100
Pioneer 1017vsx
Pioneer 51fd BluRay
Sony TAN9000es Amp.
Polk RTI8
Polk CSI3
Polk FXI6
Polk RTI4
Velodyne dps10
xbox 360
AR xsight remote
