FEEDBACK: 2001 Chevy Blazer LS ZR2 4x4
obieone
I'm looking at this vehicle w/ 80k miles, and am wondering what, if any issues to be looking for/ forward to/ be concerned with?
This is basically the vehicle I've been wanting for a while, and the price seems more than reasonable($7k), but...I'm paranoid with getting a lemon:o
Thanks for any assistance:)
Post edited by obieone on
Do a google search looking for transmission and coolant problems. Not sure about the 2001 but the 99 I had followed suit with what I read on the net.
I think it's a good vehicle, but if you can find a newer one (TrailBlazer) that would probably be more reliable.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
we've got a 2000, the vortek 4.3 is almost bulletproof as long as it gets its oil changed every few months. a common problem with these trucks is the 4wd sensor goes bad and will leave you stuck in 2 or 4, but its a fairly cheap fix. ours has over 100k miles and we've replaced everything from brake lines to door hinges. nothing unusual for a truck with this many miles. on the upside they are easy to work onpanasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
superjunior wrote: »we've got a 2000, the vortek 4.3 is almost bulletproof as long as it gets its oil changed every few months. a common problem with these trucks is the 4wd sensor goes bad and will leave you stuck in 2 or 4, but its a fairly cheap fix. ours has over 100k miles and we've replaced everything from brake lines to door hinges. nothing unusual for a truck with this many miles. on the upside they are easy to work on
Easy to work on = more $$ in your pocketpolkaudio RT35 Bookshelves
What he said.
But head gaskets are NOT a treat.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I just spent $45 for a Carfax report, and found out this things a YANKEE car. 2 years in OH, then the 7 in IL, and the most recent owner just bought it last Oct.
THAT is not a good sign:( And no mention of trans. replacement, which means it might be due:mad:I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
I used to have 97 s10 zr2 and it had a lot of problems once I got it in 2001.Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk TSi500s Vr3 Fortress modded
polk CS20 center channel Vr3 Castle modded
polk Owm 3 surrounds
polk PSW505 -
I had a 2001 Blazer. Not the ZR2. I had alot of suspension problems, leaking gas tank and some other problems. I was glad to get rid of it.
Well I just spent $278 for a set of brakes and front wheel bearings. Not TOO painful.
The guy recommended rotors as well, but I thought rotors should last at least a 100k?
My 2002 S10 only has 52k on it?I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Check the front end....it probably needs 4 ball joints, an idler arm and a pitman arm. See if the auto parts store will give you a discount if you buy ball joints by the dozen.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
thats 45$ well spent. 2 years in ohio alone means rot on the bottom. if your handy with cars than hey at least you know what your getting intopanasonic th-50pz85u
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one -
I'm lucky if i get 20k out of my rotors....
Can't really make a blanket statement like that.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
IL gets as much snow as OH. I would definately check out kbb.com as 7k sounds HIGH to me for that vehicle. I have a 2000 4 door blazer and paid 8k for it like 3 years ago...LT 4x4 50k miles. And yes, if it has the "special pink antifreeze" it can be a special treat. I forget what its called like dexcool or something just google and see the complaints. and yes the brakes kill me on this one too. I would not trade...knew what I was getting into...my 2 cents.
concealer404 wrote: »I'm lucky if i get 20k out of my rotors....
Rotors every 20k?:eek:I never want to be a passenger in anything your driving:p
I get the feeling you spend a lot of your time behind the wheel saying "Hold my beer, I want to try something":DI refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Waaaaaaaaaaa!!George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Hahah, and those aren't cheap rotors either... I burn through a set of Brembo Blanks to the tune of about 2 sets every 3 years.
It's not a regular street car.It sees track and autox abuse, and the pads that i use are REALLY hard on rotors.
But you're more than welcome to be a passenger, you might have a blast!I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
