Looking for a subwoofer to compliment the rest of the speakers i already have
Larryjepson
Hello im trying to get some ideas on which way i should go.Im looking to get a Subwoofer that i guess isnt to overpowering but goes well with the set-up i have.I will tell you what i already own & we can go from there.I have a Pair of RT600I's for Rear speakers & i also have a Pair of RT800I's that im using for my fronts.I also have a CS400 Center Channel & im looking to add a Subwoofer to the mix Any Suggestions.I was thinking the PSW650 Or the PSW505 if i can find them but again these might be to overpowering but if i could get some ideas that would be great.Ok take care thanks for all your input
Post edited by Larryjepson on
Really could use some parameters to work with.
Room size,listening preferences, and of coarse the most important,budget.
Then someone will I'm sure be glad to help.Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU. -
You can probably find a PSW1000 used for a good price. It's a very musical sub and will do justice for home theater as well. I had one before upgrading to an SVS and enjoyed it while it was in my setup. I don't think you'd find the other subs you mentioned overpowering since you can control the crossover settings and volume to your taste and room size.____________________________________________________________
