Which one to choose "PSW 110 or PSW 125"
balasenpsp
balasenpsp Posts: 3
Hi Friends,
I am about to buy polk sub this week to complete my TSI series HT setup.My room measures 14 * 12 feet and I have shortlisted PSW 110 and PSW 125.I could be pleased if any one could suggest which one is best suitable for my room dimensions.
My system is,
TSI 400
TSI 100
CS 10
Denon AVR 1908
Sony DVD Plyr
Panasonic Viera Series Plasma 42 Inches.
.............Planning for PS3 Slim to play BR disc
You may visit my "polk system showcase" section to see some photos which I have added.The showcase link follows,
http://www.polkaudio.com/forums/showcase/view.php?userid=107866
BR
Balasen
  • packetjones
    packetjones Posts: 1,059
    edited January 2010
    I personally have the psw110 and it is ok. I am currently looking to upgrade it soon as i want a little more punch for HT. Depending on the budget that you have i would also look into the dsw and micrpro line of subs as well.
    Thats a nice looking setup you have there. Very clean. Looks like you need so treatments on either the floor or the walls. The bare walls are terrible for acoustics. Overall though it looks great.
    Welcome to the club .
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • balasenpsp
    balasenpsp Posts: 3
    edited January 2010
    Tks Packetjones,
    I forgot to mention that my current setup is still a WIP when sound proofing is taken into account.I am looking to add some carpets to cover entire floor area and some sound absorbant material in walls as per experts opinion.
    edited January 2010
    WELCOME TO CLUB POLK!
    I would go with the PSW125 in that series and if you have the money you would be well-advised to move up to the DSW600 a much better sub that will last you for a while!
    cnh
  • balasenpsp
    balasenpsp Posts: 3
    edited January 2010
    Hi Cnh,
    Does going up the order in Polk Sub category will over power my room and also makes me to feel TSI 400 underpowered ? I would like to reiterate my room dimension "14 * 12 feet".That's the reason why I am thinking around PSW 110.
  • keeneyrm01
    keeneyrm01 Posts: 80
    edited January 2010
    You might also want to take a look at the PSW-111. I was planning on going with the PSW125 until i went to listen and talk to some people the the speaker shop. The 125 and 111 use the exact same 150 watt amp, which seems like it under powers the larger 12 inch speaker but is a good match for the 8 inch. The 125 can go slightly lower because of the larger woofer but its hardly noticeable when doing test loops. The same power in the smaller 8 inch gets more accurate sound especially for music. I was expecting this sub to disappoint me but it far exceeded my expectations. My room is 13x20 with listening area of 13x15 with a 7 foot ceiling in the basement and it rattles the 3rd floor during movies. Sub is turned to 3/4 on the volume knob and receiver sub level is at -1, so plenty of room to turn it up.
    HT basement room:
    TV- 42in Panasonic S1 Plasma
    A/V Receiver- Onkyo NR807
    Blu-Ray- 80GB Sony PS3
    Power Supply- Monster HTS-1600
    5 Disc Sony CD/DVD Changer
    Time Warner HD Cable Box
    Speakers:
    Front- Polk RTi A3
    Center- Polk CSi3
    Side Surround- Polk RTi4
    Back Surround- Polk RM6750
    Sub- Outlaw Audio LFM-1 EX
    Bedroom:
    32in Visio LCD, Sony STR-DE685 AVR, MTX Monitor 12, Sony 5 disc DVD changer
    edited January 2010
    Essentially I'm thinking in terms of a sub you could keep for a while and use in an even larger room...no the PSW125 is not too big for your room nor is the DSW600 because you can 'tune' down the bass!
    The PSW111 is also a good sub (mentioned above).
    What you must remember is that the tower speakers you have can almost reach into the PSW110s range or pretty close to it. For HT, especially you want something that will dig into the low 30hz zone as a minimum performance level. The DSW600 will get you to 25hz which is almost bass that is 'felt' as well as heard..GREAT for LFEs in a movie...will rattle your house.
    But I do like the PSW111 for 'music' it's a nice choice for that!
    cnh
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2010
    I agree with the suggestion for the 125, I have one in a similar sized room and it really performs well. While the DSW600 would probably be a better sub all around, the 125 does an excellent job for the cost. Also, look into the PSW505 as well, Newegg has it for $250 shipped and it would be a more "future proof" sub IMHO. Welcome to Club Polk.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • keeneyrm01
    edited January 2010
    just another though. Polk is doing this deal now if you spend more than 500 bucks on speakers or subs you get the PSW111 for free. It works slightly different at different stores but crutchfield is advertising it until feb. 20th. You might get a really good set up if you bought a DSW pro500 for 550 and get the PSW111 for free (300 dollar sub, not a bad deal). Looking at your room set up you would probably place the sub along the open wall between the stand and one of the towers, bass seems to get more dispersed in a location like that. Placing a second smaller sub closer like the side of the couch might give you really good sound especially for movies.
    HT basement room:
    Speakers:
    Front- Polk RTi A3
    Center- Polk CSi3
    Bedroom:
