ICs for RTi10s w/ Emo & Yammy
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited February 2010
    BlueFox wrote: »
    Mapleshade Clearview Ultra-Thin with Plus
    http://shop.mapleshadestore.com/prodinfo.asp?number=ULTRATHIN
    Everything became clearer, more detailed, precise, etc. with these cables. As described above, leaves rustling, glass breaking, footsteps, etc. are now more pronounced.
    The replaced GoldX RCA IC cables from the Computer Cable Store.
    http://www.computercablestore.com/GoldX_Audio_RCA_catID1317.aspx
    Wow, those are interesting cables! Completely different concept than anything else I've researched. Sounds like they're just right for you. :)
  • Huck344
    Huck344 Posts: 453
    BlueFox wrote: »
    I already have a pair in my living room two channel system. They replaced 20 year old SDA-2 speakers. I love them. They are so revealing you can hear all kinds of things in CDs you never knew were there before. Of course, I had to upgrade the speaker cables and add vibration isolation before everything became really clear.
    One point is that I would listen to 2 channel music in the HT with the LSi15s and think they sound almost as good as the PSBs. Based on that observation, and that both models are 4 ohms, I bought the PSB Synchrony One Center for the HT, and it dropped right in. I did not have to adjust anything when I reran the setup. SPL was the same from all speakers. The PSB Center blends in perfectly with the LSi15s, but provides a bigger, clearer center. I really do not need to replace the LSi15s with PSB towers, but have the upgrade bug.
    Thanks for the review. . . I've only heard them in a store, but never in a "real life" situation. I'm between those and the Dynaudio Contours S3.4. . . I have a friend that can get me a deal on the Conntours. But, I've never heard the towers, only the book shelfs. Anyway, your review helped me out on the PSB. . . Thanks.
