CSI A6 Depth
tennyis
tennyis Posts: 3
edited January 2010 in Speakers
Does the advertised depth of the CSI A6 (14") include the power port on the back? I looked at one in the store and it looked a LOT deeper then 14" when you factor in the ports.
I am hoping to go with the 6 but, I don't really want to buy a whole new wallunit just to fit it (top shelf I have is 9.5" so if it's only 14" I would only have to pull it out another couple inches from the wall to get it to fit.
Post edited by tennyis on
  • superjunior
    superjunior Posts: 1,632
    edited January 2010
    I just measured it, its 14 in. WITH the power port
    welcome to cp!
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • tennyis
    tennyis Posts: 3
    edited January 2010
    awesome I think that could work then! I will just have to move the stand out from the wall another couple inches, with the RTI A7's in the way though you can't really tell anyways! . Thanks for measuring!
