RTi4 or RTi6
Mauskar
Mauskar Posts: 104
edited January 2010 in Speakers
Debating between RTi4 or RTi6 as rear speakers. Currently have an HK AVR 347 running off an Adcom 555 with RTi12's (i love these speakers). Pretty much getting the CSi5 for the center channel and wanted to know how the RTi4's sound with the 12's and CSi5 combo? For overall SQ which is better?
thanks
Post edited by Mauskar on
  • lmacmil
    lmacmil Posts: 122
    edited January 2010
    Mauskar wrote: »
    I have not heard either but being from the same line, I'd imagine they sound very similar. Slightly better bass from the larger woofer in the RTi6 but as rears with an 80hz cutoff from your room calibration, I doubt you would hear any difference. I am debating between these two for fronts and will probably end up with RTi4s because they are more readily available and cheaper.
  • ALL212
    ALL212 Posts: 1,664
    edited January 2010
    I've got both 4's and 6's. 6's are better all around and to be blunt I was suprised by that figuring they would sound similar.
    4's are ok for surrounds but I wouldn't want to listen to them as my only speakers.
    Aaron
    Enabler Extraordinaire
  • Mauskar
    Mauskar Posts: 104
    edited January 2010
    thanks for the replies. basically trying to complement my front and center channel (RTi12 and Csi5). So dont need bass, but more concerned with SQ...
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2010
    I agree, they're both tonally well balanced. I'd suggest the pair you get the best deal on.
  • Mauskar
    Mauskar Posts: 104
    edited January 2010
    $150.00 for the pair. Is that a fair deal for them? does anyone know any deals for the Rti6's?
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited January 2010
    Mauskar wrote: »
    Well, I got my RTiA3s (the successor to the RTi6) for $219/pair on the Polk Ebay site - but you'll have to be patient for another pair to show up.
    They say patience is a virtue... :D
  • renowilliams
    renowilliams Posts: 920
    edited January 2010
    Mauskar wrote: »
    thanks
    I have the rti6's for surrounds and have been very pleased with their performance. As stated, the 4's would work well too.
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • rancid
    rancid Posts: 9
    edited January 2010
    I have the RTI4's down in the basement hooked up to a pioneer amp that's over 15 years old! It sounds great...and probably would sound better if I had a better amp running them. I'm quite happy with them. Got them for $149/pair on a boxing day sale here in Canada.
  • Mauskar
    Mauskar Posts: 104
    edited January 2010
    So been researching, and wanted to know if the Monitor 40's would be better than the Rti4's for rears? Everything I have read about them are good.
    Or since I have RTi12's should I stick with RTi series speakers
    edited January 2010
    I'd stay in the series...it will give you a more seamless sound....you don't need the extra bass back there...let your SUB handle that!
    cnh
