ques about sda 2b
mcintosh12
mcintosh12 Posts: 4
edited January 2010 in Forum Testing Area
i have recently picked up a pair of 2b sda's with no interconnect cable ive been using a rca monster cable in the round sda port tested the sda by turning the balance knob and heard the sda effect on both channels for some reason to me they sound better without the cable in is there that much of a difference between the the real cable or will they sound the same or how placement sensitive are they any thoughts?
Post edited by mcintosh12 on
  • danger boy
    danger boy Posts: 15,722
    edited January 2010
    placement is important to any speaker.. but if you are getting the SDA sound then it appears your speakers are working fine. there will not be any difference if you had a SDA interconnect cable.
    i run my 2B's both ways... with and without the cable.. just depends on my mood. one thing SDA owners forget sometimes is that the SDA speaker is a fine speaker even without using the interconnect cable. ;)
    That's probably the reason Polk Audio made the cable easy to remove.. instead of making it a permanent connection somehow.
    Listen to your speakers whichever way sounds best to you.
    congrats!
    PolkFest 2012, who's going>?
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    Welcome to Club Polk mcintosh12. I would seek out an original SDA cable. IMHO it will be safer and probably sound better than what you are using.
    F1nut Posts: 52,133
    edited January 2010
    Al, if they made it permanent then how would you move the speakers!?!
