Need help with monsoon system in '00 Jetta
![CharlestonJetta](https://we.vanillicon.com/e901abb927e0b714be08fb1fae7db430_100.png)
CharlestonJetta
I have the factory installed monsoon stereo system with six changer in the trunk of my '00 Jetta. Only one speaker - on the front right side - is working now. I fear it will go out any day since it occasionally crackles and if I hit a bump the volumn will go up and down. The dealer says the speakers are not shorted out and cannot be fixed. The entire stereo system has to be replaced. I don't trust the dealer and suspect they are lying. But that said, can the speakers be fixed or will I really have to replace the entire system?
I am new to this forum so thanks for the help and sorry if this has been covered before.
![:) :)](https://forum.polkaudio.com/resources/emoji/smile.png)
Post edited by CharlestonJetta on
the dealer is probably correct.
CharlestonJetta, do you live in Charleston, SC or Charleston, WV?
