Help ID This Polk Sub
sake
sake Posts: 2
edited January 2010 in Speakers
Hello,
I am in need of some help trying to figure out if I should pull the trigger on a sub that is available near me. The seller is telling me that it is an RM series sub but I can't find any info on the web. I believe it was part of a satellite system.
I am looking for a sub to use with my R30's. Based on the blurry pictures, I'm unable to tell if this sub has an adjustable crossover. Any help would be great.
Thanks,
sake
Post edited by sake on
    Tony M Posts: 11,619
    edited January 2010
    I think it came with a 6500 system. I don't see a crossover either.
  • Reimer
    Reimer Posts: 53
    edited January 2010
    I think that's a PSW Ancient300.
  • sake
    sake Posts: 2
    edited January 2010
    Thanks Tony, you nailed it. After confirming that with the seller I think I'll pass on this as the reviews don't seem too favorable for the sub working well without the satellites.
