Power Amp question
sageleo
sageleo Posts: 170
edited January 2010 in Electronics
I have a friend that has a NAD 214 and a NAD power envelope 2100. He is selling both of them which one would you say is better and what do you think is a fair price for either?
Thanks,
Dirk
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
  • agfrost
    agfrost Posts: 2,474
    edited January 2010
    I've got a couple of the 2100PE amps, and think that they're quite nice--One thing to check is that NAD amps of that vintage often have problems with the output relays, which can cause low volume cutouts in one or both channels. They may not have the problem, or can be treated by cleaning or replacement if they do (One of mine occasionally exhibits this, haven't done anything about it).
    No experience with the 214.
    Here's a link that describes one repair shop's thoughts about the relay issue (see the 2200/2600/2700 paragraph) as well as describes a few issues with the 214. Not gospel (to me any way), but it's some info from a source that's familiar with NAD.
    LINK
    That said, I've enjoyed my NAD amps and think they're a decent, fairly economical intro into separate amplification.
    Good luck.
    Jay
    Jay
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2010
    I have the 214... very good sound. The 2100's are great too. There's a review out there for the 214.
    http://www.tnt-audio.com/ampli/nad214e.html
    Not a ton of power but more than enough for my uses!
    Main Surround -
  • Quality321
    Quality321 Posts: 18
    edited January 2010
    I own 2 NAD 214, I run them bridged to my RT55i and they love them... They are well controlled and have more then enoungh power in reserve to drive these speakers... The NAD'S have really fine tuned the tweeters in my Polks they are alot more sweeter and smoother then they where.. The mid range drivers have come to life, no more muffled sounds just smooth and very well controlled...
    I resently did a A/B conparision, running one amp in stereo vs two.. one amp did a great job, but I felt I needed more power so I bridged and my system came to life... I dont think you should pay anymore the 200.00 for 214 and thats mint... For the sound that these babies put out its a easy bargin ....
    Nad complaments the Polks wonderfully......
    If you decide not to go with 214 let me know I'll take it off you buddy's hands.... I am currently looking for another to run bridged on my center... Polks CSi40
    Polks All The Way
    Fronts RT55i
    Front Presence RT35i
    Center CSi40
    Side Channels FXi50
    Rears RT55i
    Rear Presence RT15i
    Bottom Line, Greatness and Fun....
  • sageleo
    sageleo Posts: 170
    edited January 2010
    Thanks for all the info! I did pick both of them up, with the only real problem being that my audio cabinet that i just had built doesn't fit both of them. So, I guess my next question is which one should I use? I have the 214 hooked up now going to my center channel speaker. With my H/K powering my L/R. Since the 2100 has channels A/B could I run rca's from the L/R pre outs to the input on the amp and bi-Amp my fronts with lets say speaker A powering my highs and speakers B running to my mids? or would I be better off powering my center channel? Sorry if that does't make any sense.
    Thanks again for all the help and info,
    Dirk
