How to remove the grill covers from the LSi15 woofer?
I'm thinking about replacing the 8" sub driver on my LSi15's and can't seem to easily remove the grill cover to get a look at them. I don't want to damage the grill or (especially) the wood cabinet, so can anyone give me a tip on how to get them off?
Thanks.
Thanks.
Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH
Post edited by tcrossma on
Go to your local tool/automotive store and ask for a pick.
Something like this: http://stores.homestead.com/nicoleclark/catalog/pick.JPG"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I have something comparable to that. So just gently work the outside of the grill to work it up? There's just not much of a lip to work with -- maybe only about 1/8" -- sticking up from the wood cabinet. Does it take much to get it off, or just have to give it a little help?
Thanks for the help.Speakers: Polk LSi15
Phono Pre:PS Audio GCPH -
It may need a little help the first time. Just take your time."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I use my fingernails to remove them...grap the outside portions with your nails using 8 of them...it's not hardVideo: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
