Preamp to Amp impedance matching
thsmith
thsmith Posts: 6,082
edited January 2010 in Electronics
I need to help to make sure I understand what I am looking for in my next Tube Pre that will be connected to my Anthem AMP 1 with input impedance of 100K ohms. Also I am using MITs S3 Shotgun ICs.
I have read where a Pre Amp should not have more than 500 ohms output impedance.
Is there more to it than that?
What else should I look for?
How do the MITs come into play with its impedance selector box?
Thanks,
Post edited by thsmith on
  • Ricardo
    Ricardo Posts: 10,636
    edited January 2010
    With that input impedance you won't have any problem. I've used the rule of thumb that there must be a minimum of 20:1 (read it somewhere) between the amp's input and preamp's output, so you can use virtually any preamp. If your IC's have the selectable impedance, just use the highest (should match the receiving equipment).
    SOPA
  • thsmith
    edited January 2010
    So if my Pre has output impedance of 137 ohms and my Amp input impedance is 100K ohms then I have a 740 to 1 ratio ?
    wrt the MITs I was wondering since the cables (I guess) are trying to impedance match does it even matter ?
  • Ricardo
    edited January 2010
    thsmith wrote: »
    Pretty much. As I said, amps with such a high input impedance are not a problem; my amp has an input of 22 kohm, so it makes it a bit more difficult to match; there are preamps that have output impedance of over 1 kohm.
    with the MITs I was wondering since the cables (I guess) are trying to impedance match does it even matter ?
    The MIT's have to be set to match the receiving piece of gear; I am not sure how it works with the sending equipment or if it even matters.
    SOPA
  • thsmith
    edited January 2010
    thanks Ricardo !
  • headrott
    headrott Posts: 5,496
    edited January 2010
    My amp (Aragon 8008bb) also has an input impedence of 22Kohms. My tube pre-amp has an output of (to quote AMC specs <200 ohms). That's not very specific. So, let's assume an output of 175ohms. So my ratio would be 125:1 (approximately). I guess that's not too bad huh? I should be fine then, correct?
    Greg
    heiney9 Posts: 25,432
    edited January 2010
    headrott wrote: »
    Greg
    I see you're still obsessing over this, YES you'll be fine :):);).
    Perhaps you should sell your seperates and get an integrated or a receiver :p.
    Let it go...........just fo' get about it!
