Hooking up Dual PSW450's...
Grimster74
Grimster74 Posts: 2,577
Here's my question, I currently purchased a Sony STR-DA4ES receiver. The question I have is my old Sony receiver (STR-DA3ES) had dual subwoofer outputs where as the new receiver only has a single subwoofer output and I'm running dual PSW450 subs. What is the best recommended way to hook both subs up to get maximum output. Will a Y-adapter work the same as having dual subwoofer outs or can I run the speaker wire from the receiver to the left INPUT of the sub, then to the left front spaeker and the same for the right side or do both inputs on the sub have to be hooked up the make it work correctly. My current set up is Fronts are RTi70's, Center is a CSi40 and Rears are from my first RM setup which are soon to be upgraded and of course Dual PSW450's. A sales rep at the store mentioned something about daisy chaining the subs, what ever that means. Any help will be greatly appreciated.
Post edited by Grimster74 on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited April 2003
    Y splitter will be fine.
    Daisy chain = sub out > Sub#1, Sub#1 line out > Sub#2 line in.
    Cheers,
    Russ
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited April 2003
    I like the Y-splitter too, over daisy chaining. Less potential for noise/distortion to be generated and carried from sub #1 to sub #2.
    If you are utilizing the electronic bass management circuitry at the AVR, then connect each sub cable to the single LFE (Unfiltered) input on each 450 to avoid cascading the AVR and sub filters.
    Doc
    SVS
  • PETERNG
    PETERNG Posts: 915
    edited May 2003
    In my experience and I did this before, many times, two subs never sound better than one. I have the PSW150 for the bedroom system, don't get me wrong, this is a good sub that match up with my RT 55i very well, but I always feel that the bass is not powerful enough for music and for some movies. Then I add on the AR-115 sub and carefully adjust the reverb switch and locations for the sub, but it just doesn't sound right. Finally I decide to sell the AR-115, gave the PSW-150 to my young son and replace them with the new JBL S120PII, and everything comes to live, the JBL produce very powerful deep bass, great for music and for movie, you will need to hold on to your bed sometimes. I still love the Polk monsdo Sub PSW-1200 in my living room.
    Here is my set up for the bedroom
    Yamaha 5590 A/V receiver
    CS-350 center
    RT-55i main
    RT-25i rear
    CS-300 rear center
    JBL S120P II sub
    MC M series bi-wired for main, single for center
    MC 10 gauge cable for all rear channels
  • BeginnersLuck
    BeginnersLuck Posts: 213
    edited May 2003
    One sub is better than 0 subs....
    Two subs are better than 1 sub....
    Well, I guess it depends on the sub...heh
    Oh yeah, use the y splitter...but steer away from rat-shack if you can...my y splitter from rat-shack was supper noisy...(I had to use monster) They cost the same...
    -BL
    TWFTPQ
    Receiver: Outlaw 1050
    Amps: Outlaw M-200 x 3 (Powering Mains and Center)
    Mains: RT800i; Center: CS400i; Surrounds: F/X500i
    Sub1: 214L Vented Tempest
    Sub2: 122L Sealed Tempest
