Are RC85i's and RC60i's a good match for RTi8's?
Hello all. It's been a long time since I've been on these boards. The wife and I just moved and due to some space limitations in the new pad, I need to change out my surrounds and rears of my 7.1 system to in wall/in ceiling speakers. My fronts are RTi8's with a CSi5 Center. I was thinking of installing RC85i's as my surrounds and RC60's as my rears. Anyone know if this is a good match in terms of timbre?
Thanks in advance!
Thanks in advance!
Post edited by Huck344 on
You can probably get away with these in-walls since timbre matching is not as critical for surrounds as it is for the front three speakers. Ideally it would be better if at least the tweeters matched all around, but due to your space considerations, it looks like this will not be possible. Don't know of any in-walls that have the Rti series drivers
The TC series is the correct match. I have them and you will be happy...
Thanks for the answers. I'll have to take a listen to the TC's.
