Do I need to bi amp?
k0tuynh
k0tuynh Posts: 144
edited January 2010 in Speakers
Hi all,
Thanks for reading my post.
Here is my set up.
Front: Monitor 70
Center: CS2
Sub: CVS PB 10
Receiver: Yamaha 863.
My room is small 15' x 12'
My question is, do i need to bi amp my front speakers? if so, which power amp is the best?
Thanks,
Post edited by k0tuynh on
  • lmacmil
    lmacmil Posts: 122
    edited January 2010
    k0tuynh wrote: »
    Here is my set up.
    Front: Monitor 70
    Center: CS2
    Sub: CVS PB 10
    Your room is small, your amp is pretty powerful, your speakers are pretty efficient. The simple answer is no.
    Do you want higher volume? More clean headroom? Want to spend more money? Want to brag about your setup? Then yes. :D Just don't expect some magical improvement in the sound.
  • k0tuynh
    k0tuynh Posts: 144
    edited January 2010
    Thanks lmacmil,
    This is my 1st HT set up.
    The receiver should be here on the 20th. Can't wait.
  • curved
    curved Posts: 664
    edited January 2010
    I would wait and see....you may be very happy with the results. If not, you can always add an amp with your setup.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
