Rti10
AeR0
AeR0 Posts: 102
edited January 2010 in Speakers
so ive just ordered a pair of
towers: Rti10
centre: need suggestions??
rears: Rti4
am i on the right track am i buying good stuff? and do i have the proper rears??
Post edited by AeR0 on
  • math wizard
    math wizard Posts: 106
    edited January 2010
    You are getting good stuff. For a center get a Csi5 or its replacement the CsiA6 (either will match the Rti10's). Your rears are OK, but you could try speakers out of the Fxi series. You may want to look into getting a sub and an amp to power the Rti10's. External amplification will make those babies sing.
    Processor - Emotiva UMC-200
    Pre-Amp (2 Ch) - Emotiva USP-1
    DSP Minidsp nanoAVR DL
    DAC (2 Ch) - Emotiva XDA-2
    Amp (Fronts) - Emotiva XPA-2
    Amp (Center/Surrounds) - Emotiva XPA-3
    CD - Emotiva ERC-1
    Fronts - Polk Audio RTi 12
    Center - Polk Audio CSi5
    Rears - Polk Audio RTiA1
    Sub - Epik Knight
    Sub EQ - Velodyne SMS-1
    Monitor - Sony XBR65X850C
    Blu-Ray - OPPO BDP-203
    Network Media Player - Chromecast Ultra
    Power Conditioner - APC H15
    Power Conditioner - Emotiva CMX-2
    PVR - DirecTV C61k
    Remote - Harmony Touch w/Hub
  • AeR0
    AeR0 Posts: 102
    edited January 2010
    yeah i saw the csi5 and the csiA6... what would u go with and why?
  • acsubie
    acsubie Posts: 773
    edited January 2010
    for the center I highly suggest the CSi5..its a great center, but it is on the large side so thats something to consider. Your setup is very similar to mine. But I use the RTi s for SL/SR duty and another companies for SRl/SRR. If you plan on wall mounting the the surround speakers and want more of a "flush" look, check into the FXi series as they are more of a dedicated surroung speaker
  • math wizard
    edited January 2010
    AeR0 wrote: »
    They are both the same. The Csi5 is the older model and can be found cheaper than the CsiA6. They both have the same drivers and the same specs.
    CD - Emotiva ERC-1
    Sub - Epik Knight
    PVR - DirecTV C61k
  • acsubie
    acsubie Posts: 773
    edited January 2010
    i believe the cabinets slightly differ also with the CSiA6 being less "boxy"
  • MADGSF
    MADGSF Posts: 603
    edited January 2010
    Agree with the above statements, they are the same except for the cabinet. That being said if you can get a CSi-5 at a good price that is what I would get.
    I have pretty much the same setup and agree that an amp will help the RTi10s a lot, especially in the bass department. The rears are fine unless you are wall mounting then as suggested I would look at the FXi series.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • curved
    curved Posts: 664
    edited January 2010
    As the others said, go with either the 5's or A6 if you have the room. The cabinets and grills are a slightly different from one another though. I would shop around and see which one you could get cheaper.
    Nice setup BTW!!
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • troyst123
    troyst123 Posts: 12
    edited January 2010
    Just got the CSi5 myself. One thought with either the the 5 or A6, be sure you know the dimensions and consider where you will be placing it.
    I needed to get a new TV/media stand and most with dedicated center compartments have them that are too small horizontally, vertically or both. I did find a few, and I mean only a few, higher end wood cabinets that would work and some open glass shelf types (I ended up with this type that had adjustable shelf heights). If you mount your TV on the wall, then you can put your speaker on top of the stand if needed, but really, it is a big speaker! You may not want it out like that long term.
