polk audio rt 1000i
goodshepherds
I am looking for (1) rt1000i powered tower in black. I am new to the Polk Forum so maybe someone can give me some guidance here. I bought a pair new around 2000 and now one is making a loud constant humming sound. Not sure if it can be repaired or if I am better off finding a replacement. Any suggestions would be greatly appreciated. I live in central Florida.
Post edited by goodshepherds on
welcome to Polk, GS. Sorry it is a problem that got you here...
I don't have one for sale, but I think you might be able to isolate/ trouble shoot the issue without just buying a new speaker. I am sure more experinced members than I will chime in later..
Have you tried disconnection the jumper, and see if the humm is coming from your system (top drivers) or from the built-in sub?? Are you sure it is not a ground loop humm? Did you change something recently?
I seem to remember other ppl having some amp issues that related to the built-in sub amp in other models. Have you contacted Polk Customer service? They are really great about helping ppl trouble shoot issues, and they can also give you parts, if that is what it takes...Remember to mention you are a Club Polk member, they usually help out with discounts and free shipping... -
Hi and thanks for the response. I did not move or change anything before the problem started. Soon after the problem started, I did move and now they are sitting in the corner gathering dust. When I plug the bad one in to an electrical outlet (not connected to the receiver) it instantly starts humming. Its a very loud hum or buzz. Has anyone else experienced this? Thanks
Sounds like the amp, Maybe a ground loop hum? Try plugging it into a different outlet. If that doesn't work, give Polk CS a call on Monday. They will help you out. Usually you can ship them just the amp, and they can repair it/ or replace it.
I had the same problem a year ago. I shipped them just the amp, and $75.00 later, it came back working just fine....Room 1:
ONKYO TX-SR608
Polk Complete RT 5000 System
Polk RT3000p's Front
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk RT2000's Front Someone Please Sell Me Some RT3000 so I can have a second RT5000 setup !!!!
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear -
I spoke with Polk today and I will be sending it off soon. Thanks for the response.
let us know how it works !!!!Room 1:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX 1000's Rear
Room 2:
ONKYO TX-SR608
Polk CS1000p Center
Polk FX1000's Rear
Polk PSW 120 front
Polk PSW 505 rear -
Awesome, hope you are up and running soon. Go Polk CS!!
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
It's not that I'm insensitive, I just don't care.. -
I am also experiencing the same buzz, however I know that mine is coming from the built in sub, because it stops when I shut off the sub using the switch in the back. Just curious, ultimately what was your problem?? The buzz I hear is not a ground loop problem because it is not a "hum".
Thanks, Ken
Center- CSi5
Mains- RT1000i
Surrounds- f/x 300i
Reciever- Denon AVR 2803
Additional Sub- Yamaha YST SW325
T.V.- Panasonic 50" PlasmaKen Laws -
Ken, the built-in sub amp has the problem.
Call Polk CS, get RMA number and get it repaired.I am also experiencing the same buzz, however I know that mine is coming from the built in sub, because it stops when I shut off the sub using the switch in the back. Just curious, ultimately what was your problem?? The buzz I hear is not a ground loop problem because it is not a "hum".
Thanks, Ken
Center- CSi5
Mains- RT1000i
Surrounds- f/x 300i
T.V.- Panasonic 50" PlasmaPanasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
