anyone used PS Audio?
cstmar01
So I've been looking around the Agon to see if I can find some amps or amp to replace my current two mono blocks. I want something that can be used for HT easily but also for 2 channel as my rig serves for both.
Anyways came across some PS Audio amps the GCA MC's to be exact. They look really interesting, no heat sinks, ect, just wondering if anyone has acutally used them at all and their thoughts. They are saying no heat, and that the gain cells can be switched in and out. I know they are older models from 2005 and pop up on the gon but didn't know if anyone has had a chance to test them out.
just curious thats all.
Also any suggestions to some amps for the front would be nice, I would more than likely in the future just use the amps in a 2 channel set up alone just don't have the proper space right now for it. 2-3K would be the budget for the amp/amps. using them on my RTIA9's.
