CSU or 16-46PC+
I'm going to take the SVS plunge today and thought I'd get everyone's opinion. Which one would you choose and why? 16-46PC+ or the CSU. I'm going to have to drive the CSU if I get it with my Citation amp for the meantime just because of budget. My preamp has all of the settings to control output.
SDS-400, SDA-1B, SVS 20-39pc+, B&K Ref 50, Denon 2900
Post edited by kelley on
I saw your post over at HTF.
I did a review of the Ultra vs. the 20-39PC+ and posted it on HTF a few months ago - name is "Edward J M" over there.
I don't know what the rest of your system looks like, but the Ultra is very expensive and the premium over the PC+ or the CS+ might not be worth it for you.
Really it boils down to the drivers. The best comparison is the passive 20-39CS+ with the dB12 driver vs. the passive 20-39 CS Ultra with the TV12 driver. They are identical subs in all respects except for the driver.
The $575 CS+ offers about 85% of the performance of the $900 Ultra. Tom V at SVS considers the Ultra "worth every penny". I've heard both - and both are awesome and yes the Ultra IS better. Is it $325 better? Only you can decide.
With the said, the PC+ is an incredible value - the best in the line-up. You get everything onboard - variable phase, SS filter, inputs galore, 525W of BASH power. It's a home run and if it were my money, I'd buy a PC+ over an Ultra in a heartbeat.
BTW, the 16-46 is really only needed if you regularly play music/movies with 14-15 Hz content. The 20-39 is a better choice for most applications.
Doc"What we do in life echoes in eternity"
SVS -
Thanks for the info. I'm running SDA 3.1tl's for the front, cs400 center, and Boston bookshelfs for the rear, but the Bostons are going to be replaced. There's a $50 difference between the 16-46 and 20-39. You think that the 20-39 is better overall though?SDS-400, SDA-1B, SVS 20-39pc+, B&K Ref 50, Denon 2900
Well, it's the "pinch hitter" of the line-up. It plays a bit louder overall than the 16-46, but it doesn't dig quite as deep. Very few movies go deeper than what the 20-39 can play in stock tune.
If you want the ultimate in extension, and you have a moderately sized room, the 16-46 is still king. If you have a really big room (4000-5000 ft3), two of them might be a good idea."What we do in life echoes in eternity"
SVS -
Doc, I ordered a 20-39PC+ today. When shall I expect you over to calibrate it?
