Stacking Subs
rpalme1
rpalme1 Posts: 34
I have a Psw 505 and a Psw 10. Should I stack them in a corner or spread them out with one in the corner? Or option 3 not use the Psw 10 at all.
Post edited by rpalme1 on
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2010
    Optiion 3 IMHO, that 505 should be enough for your room and will probably just drown that poor 10 out. I guess you could try stacking, but again that 10 will be screaming at the top of it's lungs and all you are going to hear is that 505. Maybe use it for a PC sub? Get a couple of Monitor 40's and use it in the garage, lol. Just my $.02, maybe somebody will have better/more advice soon. Welcome to Club Polk.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Knucklehead
    Knucklehead Posts: 3,602
    edited January 2010
    Yep, Jeff hit the nail right on the head, I know its enticing to have a dual sub set-up but unless they are of the same model, probably not a good idea. I never was a fan of stacking subs.
    David
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • rpalme1
    rpalme1 Posts: 34
    edited January 2010
    Ok thanks for the info. The Psw10 goes back to the deck box outside.
    Dont want the Atrium 45's to be lonely anyway. That is what I originally
    purchased it for, but I couldnt help but try to use both.
  • Knucklehead
    edited January 2010
    Ya never know when you can pick up an additional 505 on the cheap! Good luck with your journey!
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • refinedsound
    refinedsound Posts: 26
    edited January 2010
    Interesting topic. I have been running dual subs in a musical and HT setup. One sub is a single 12in M&K and the other a dual 12in push-pull firing M&K. Y out from Sub-out on receiver single RCA to each sub. My Yamaha receiver has the YPAO setup mic, and I let it establish a the sub speaker level and make adjustments from that reference point.
    I found having the subs separated in the room can cause some cancelling of sound and that side by side or stacked works best for me and I would suggest staying away from corners as things can get a bit 'boomy' rather than accurate.
    I think properly tweaked they can easily compliment each other and I have been impressed with the quality of musical sound as well as theater sound. Experimenting with a pair I think can produce a more full level of bass as needed!
    Karl
  • dekuda
    dekuda Posts: 756
    edited January 2010
    Karl
    I think it is easier to tweak if subs are stacked. Also, I had a 505 and a mirage and they were just too differant types of subs. 505 boomey,more for HT and the mirage more tight.fast for music. I believe no matter where I positioned the subs they would cancel each other out. When I got another mirage and matched it with my other mirage everything came together. I am a big fan of having two subs but only when they are exactly the same. You will always have to experiment with positioning subs.
    HT System
    Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
  • louhamilton
    louhamilton Posts: 209
    edited January 2010
    A multiple sub environment is VERY tricky to get to sound good. It is usually more work than it is worth for most people. Even similar subs in the same room can sound like crap. There are phase issues, and room acoustics to battle.
    Even though I have never used it, I have read that the REW software over at hometheatershack.com works really well to help get a flat response out of your sub (and other speakers as well).
    If you want to try to get the BEST bass response out of your room, do the sub crawl. This is when you put the sub where you normally sit (the sweet spot) and crawl around the room until you find the place where the best sounding bass is. Another suggestion it to buy or build a sub riser. this elevates the sub off the floor and can also act as an isolator from the floor. Remember, if the sub is directly on the floor, especially, wood floors, it can use the floor for additional unwanted resonation.
    Just some thoughts as you figure out your sub placement.
  • john E
    john E Posts: 32
    edited January 2010
    I disagree if you have a big room ,I have my PSW-505 in the front corner of my room and I bought a PSW-10 to put in the back of the room.It does makes a difference ,I call it back bass rear fill.The PSW-10 actually hits the higher bass notes better ,or it tighter and the PSW-505 is good for the gut low bass.IMO
    ONKYO TX-SR607
    PolkAudio Speakers
    Front-Monitor 70's
    Center-CS2
    Sur-round-Monitor 40's
    Sur-round Back-Monitor 60's
    Subwoofer-PSW-505
    Back fill in Bass PSW-10
    LG 50"Black 1080P Plasma HDTV (50PS60)
    LG Blu-Ray Disc BD390
  • dekuda
    dekuda Posts: 756
    edited January 2010
    mikeyb wrote: »
    I have 2 PSW 505's, I arranged them in a mirror image (ex. 1 sub beside each tower) and used the setup mic for a baseline to tune them from. They really do blend in well, hard to localize them. And none of them are in the corner. They were however hard to get set up right. But once it was done it has worked great! I haven't tried stacking, but did try one at the rear of the room and just didn't sound right.
    I agree. I sold my psw505 and got a matching Mirage S10 and moved both subs like you from the corners to closer to my towers. Set them up through my Yamaha mic and I like the sound. Not as boomy but I listen to music more. I always thought subs should be in the corners but I believe they cause to much false boominess. I also agree that setting up two subs,even identical, is tricky but I believe worth trying.
    I do have qustion? My subs have two downfiring ports. Has anyone experienced problems with downfiring ports on wood floors? Cement slab is under the wood floor.
    HT System
