Serious speakers?
zarrdoss
zarrdoss Posts: 2,562
edited January 2010 in The Clubhouse
Post edited by zarrdoss on
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited January 2010
    Yes, and I'm gonna tell you why:
    THE OWNER MANFACTURE WILL SET UP SPEEKERS
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • zarrdoss
    edited January 2010
    Hopefully he will finish them first and add a few more speakers on top. How are you doing? how are those 2b's treating you?
  • Face
    Face Posts: 14,340
    edited January 2010
  • Disc Jockey
    edited January 2010
    zarrdoss wrote: »
    I'm hangin' in there. The 2b's are sublime :cool: How's everything up your way?
  • zarrdoss
    edited January 2010
    Barely hanging in there myself. going to re-do the 2.3tl and 2.3tl x-overs sometime in the future.
  • Disc Jockey
    edited January 2010
    Have you done the x-over mods before? You'll love the difference. I did the 2B's with the tl mod, well worth the time and coin. Thinking about spikes for them too, just haven't had much time lately.
  • BlueFox
    BlueFox Posts: 15,250
    edited January 2010
    Is that the tweeter on the top of the serious speaker?
  • zarrdoss
    edited January 2010
    no I have repaired some old klipsch x-overs and replaced a few bad caps but sure I can pull it off just need the $$$$
  • zarrdoss
    edited January 2010
    BlueFox wrote: »
    it sure appears that way to me
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited January 2010
    all your speaker are belong to us.
  • madmax
    madmax Posts: 12,434
    edited January 2010
    How do speekers differ from spearkers? :confused:
    Vinyl, the final frontier...
  • Jstas
    Jstas Posts: 14,996
    edited January 2010
    Face wrote: »
    I KNEW it looked familiar!
    I helped a friend build a set of those. But I don't remember putting anything on the top of the cabinets nor do I remember that recessed pocket on the back. If I didn't know better I'd swear that fool slot vented the cabinets that way.
    BTW, if anybody wants a cheap set of DIY speakers to cut your teeth on in the DIY realm, that kit from Parts Express is good! The speakers and components are quite good for the price and if you take your time and put attention to detail in construction, they turn out spectacular!
    We built his cabinets and I used an epoxy body filler to smooth and even out the surfaces. Then we painted it with a Dupli-Color "triple black" rattle can paint (don't think they make it anymore) and then covered them in a clear epoxy resin. Did 3 coats of resin, wet sanded between each and then finish sanded. Came out almost like piano black but a virtually indestructible finish. I tapped holes for rubber grommets to add speaker grills. We built frames out of cheap quarter round, painted flat black with mitered corners. Stretched, glued and stapled speaker grill cloth over them and then tapped holes for the grille stanchions on the frame.
    My dad had 1" by 2" boards of maple sitting around from building a new kitchen table for my mom. So he glued a bunch of scraps together, joined and planed the resulting boards and made top and bottom end caps. We stained it with a deep red stain to match his decor. Worked out nice and looked as good as any speaker he could have bought at the store. Ended up costing him just under $350 total and a couple weekends worth of work.
    Expert Moron Extraordinaire
  • cstmar01
    cstmar01 Posts: 4,424
    edited January 2010
    Jstas wrote: »
    I've been thinking about picking one of these up to try them out. I was just worried the stuff wouldn't be that great of quailty but think I might try it out now.
    Some of their other speaker builds are interesting such as the line source ones. The parts are like 3000 but some people say make great speakers, I just don't know if I would have the time or patient to ever sit and do that.
  • Jstas
    Jstas Posts: 14,996
    edited January 2010
    cstmar01 wrote: »
    Well, with any kit, test fit first and make sure things line up. We had to sand edges first to make sure joints were square enough to be sealed properly. That was also one of the reasons we covered it with epoxy filler and resin. It was just MDF and it's not really forgiving if you make a mistake but it's easy to finesse. So we made sure the cabinet was air tight and structurally solid. MDF is heavy, so is epoxy so they ended up being heavy but that kit above is a good solid base.
    The other nice thing about DIY speakers is that you aren't limited to the drivers that came with it. You can change them out, swap crossover components and so one and so forth. They are a good learning tool, lots of fun to mess with and the end results are very rewarding. The hardest part about building them is the finish work. But like any pro can tell you finish work is 90% prep work. That makes the most difference. Take your time and be patient and it'll end up very nicely.
  • Lowell_M
    Lowell_M Posts: 1,660
    edited January 2010
    madmax wrote: »
    Spearker Cables = Fact
    Speeker Cables = Fiction
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
