Need Rear speakers
Bigtom2000
I am looking to complete my speaker set.
I currently have
Receiver: Onyko HT-RC180
Fronts: Monitor 60
Center: CS1
Sub: PSW110
I am looking for rears possibly ones that can be wall mountable.
I was considering the
Monitor 30
Monitor 40
TSi100
TSi200
A1
A3
I do have a large living room, but at this point I am thinking about only doing a 5.1 setup, but if I would like to have the option to upgrade to a 7.1 in the future.
Any advice you can provide would be greatly appreciated
Thanks in Advance,
I currently have
Fronts: Monitor 60
Center: CS1
Sub: PSW110
Monitor 30
Monitor 40
TSi100
TSi200
A1
A3
Thanks in Advance,
Post edited by Bigtom2000 on
Stay within the line, M40s would be my choice.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Just posted this. A pair of Polk monitor 30's from Newegg $95.oo shipped:DHT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ. -
Oops, forgot link for newegg speakers!
http://promotions.newegg.com/NEemail/Jan-0-2010/CES/index-landing.html?nm_mc=EMC-IGNEFL011210&cm_mmc=EMC-IGNEFL011210-_-email-_-E0-_-GoldHT System
The M30's wall-mount easily, as well. They come with the bracket and offsets pre-mounted. You just need a single screw into an anchor or stud.
And, they sound shockingly good for a speaker of that size and price. (I paid $89/pair.)Gary
Living Room
Panasonic TC-P50G10 Plasma - DMP-BD65 Blu-Ray - DMR-EZ28 DVD Recorder
Dish VIP722k - Roku XD - Slingbox HD - Sony NSZ-GT1 GoogleTV
Denon AVR-3311ci - Polk Monitor 70, Monitor 40, Monitor 30, RM6751, DSW Pro 400 -
I agree that you should stay within the family for the surrounds, although it is not as important as timbre matching your front three. The 30's are very easily wall mounted via the key hole slot. The 40's not so easy, but with a little effort it can be done. If not, are stands an option for you, IMHO the 40's are a way better speaker than the 30's, not that the 30's are bad. Also, one more idea, was your choice of the CS1 over the CS2 due to the CS2's "girth" If not, I would suggest upgrading your center to a CS2 at some point in time, you don't know what you are missing. Running the 60's as your fronts, the CS1 may have a hard time keeping up and you may find yourself with remote in hand, constantly playing the up, down game with the volume. I have heard from more than one person that the CS1 is an ok match with the 60's with a little tweaking. Hope this helps, and welcome to Club Polk.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
It's not that I'm insensitive, I just don't care.. -
Yeah I will admit that I actually bought the CS1 and the Monitor 60 because the reviews were good and they were onsale on Newegg. I really didn't do too much research at the time.
I will probably go with the Monitor 40 on stands.
Now about the speaker wire, I would like to avoid buying the "named" brand wire as i feel that it is just more expensive.
Can someone suggest some decent speaker wire, I would assume 12 AWG is what i want.
Do i need Oxygen-Free Copper Speaker Wire? Is CL2 ok for in wall installation?
Is anything at Monoprice any good?
Thanks,
