bass management
hondo55
hondo55 Posts: 4
a little confused about bass management. my receiver is a marantz 6200 home theatre system.i have a subwoofer and polk centre and surround speakers. should i have speakers set at small or larger and what difference does this make.
Post edited by hondo55 on
  • mjm1124
    mjm1124 Posts: 11
    edited January 2010
    From Marantz:For the purpose of establishing proper bass reproduction, use the
    LARGE settings if the speaker being used at any position is a
    traditional full-range loudspeaker that is capable of reproducing sound
    below 100 Hz and you are not using a subwoofer.
    Use the SMALL setting for smaller, frequency-limited speakers that are not
    able to reproduce sounds below 100Hz and you are using a subwoofer.
    Low frequencies will be diverted from the speaker to the subwoofer.
