subs in the floor
mhmacw
mhmacw Posts: 832
if i was to put a sub under the floor what would be the best place to put it in relation to the screen? room is 36x16 the screen is on the 16 ft wall centered. i have access to the entire floor .the surrounds are 30 ft from the screen on the opposite wall.
  • domflane
    domflane Posts: 653
    edited January 2010
    Under the couch. That would be awesome for HT. The sub is still going to have to be in a good enclosure though.
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • TNRabbit
    TNRabbit Posts: 2,168
    edited January 2010
    You need to Google "Cult of the Infinitely Baffled"....
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • mhmacw
    mhmacw Posts: 832
    edited January 2010
    im not going to be able to port it through the floor. do you think it would still work ? and also the tight bass is what im after. do you think i should use the psw 10 for the rock and roll and the homebrew 15 for the ht? i think an av switch wouldnt be too hard to do and with signal sensing amp it would work ?
  • Knucklehead
    Knucklehead Posts: 3,602
    edited January 2010
    The last time I saw a sub in a floor, it was firing up out of a false air vent. It was all Bose!
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • mhmacw
    mhmacw Posts: 832
    edited January 2010
    TNRabbit wrote: »
    (in a sarcastic voice) thanks a lot... now i have an entirely different set of ideas running throuhg my head lol.
