Polk PSW450 or Martin Logan Dynamo
POLKHT
POLKHT Posts: 138
edited January 2010 in Speakers
I currently have PSW450. Is the Dynamo a better sub to get.
Thanks.
Post edited by POLKHT on
  • concealer404
    concealer404 Posts: 7,440
    edited January 2010
    What are you using it for and in what size room?
  • POLKHT
    POLKHT Posts: 138
    edited January 2010
    I'm going to use it for 80 HT /20 2CH. Not sure on the room size. I'm going to move soon and don't have the room size. The room is not too big.
    edited January 2010
    Isn't there more than one size of Dynamo? Which model?
    cnh
  • POLKHT
    POLKHT Posts: 138
    edited January 2010
    The Dynamo comes in a 10 inch, 200 watt RMS, sealed. The next one up is the Abyss.
    edited January 2010
    Dynamos are available in 12" and 10" models...see onecall.com Either one digs lower then the 450. If that's a consideration..so I'd say, on paper, it would be an upgrade!
    cnh
  • POLKHT
    POLKHT Posts: 138
    edited January 2010
    I did not know it came in a 12". Thanks for the info. Another sub to consider.
  • apphd
    apphd Posts: 1,514
    edited January 2010
    POLKHT wrote: »
    Those are new offerings, there was just the one Dynamo, but now it looks like they offer the Dynamo: 500, 700, and 1000 not sure how they would compare to the original, which was pretty good. I would guess one of those to be an equal, one a little better, and one not as good but something to market in the $400 price point.
