Five channel surround and HDMI TV
joeygrand3
joeygrand3 Posts: 41
edited January 2010 in 2 Channel Audio
I have a Samsung 46" DLP HDTV television. I am using a Yamaha AV receiver and Polk Monitor speakers.(POLK Monitor 40 for front and rear. Polk Monitor CS2 for the center and a Velodyne woofer.) The problem I am experiencing is that when I am viewing any HD movie from cable TV, I get sound from the center, the woofer, a front and a rear speaker. I have to select five channel stereo To drive all the speakers. However, when I am viewing a DVD movie, I get surround sound from all the speakers. I dont know if I have a wiring problem or a receiver problem. Please help.
JOE
Post edited by joeygrand3 on
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited January 2010
    If you get sound from 1 front speaker and 1 rear speaker, you may have it wired wrong. Even though you get all 5 from DVD, you may not be getting the correct channel in each speaker.
  • MANSKITO
    MANSKITO Posts: 295
    edited January 2010
    that sounds like a wiring problem to me, also please note that Cable broadcast is generally not in the same high ress formats that you find on optical media (DVD, blu-ray etc..) so its never going to sound the same.
    Generally you should get A LOT of sound from the Center speaker and woofer, some sound from the front right and left, and almost no sound from the rear speakers.
    Very little information gos to them and you will only notice there presence if say like a plain or something comes from behind you in the movie.
    on a side note theres no real point to 5 channel stereo unless you just want louder volumes, if something is not mixed natively in 5.1 its going to sound better in what ever it was mixed in.
    My advice is just leave your AVR in pure/direct mode let it decode the audio in what ever native format its coded in for best sound.
    Also re check your wiring, if that dose not help call the support lines of Yamaha/your cable company or wait for some one smarter to post.
    Monitor 60s, CS10 front
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    Pioneer PD-5010 CD player
    Sennheiser HD 650s :D
    Maverick Audio Tube Magic D1 DAC
    AMD Phenom II 940 @ 3.8 prime stabel
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
    Creative X-fI Titanium Fatal1ty
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2010
    MANSKITO wrote: »
    Don't sell yourself short man, you pretty much nailed it. Very good post, and other than a wiring problem, this could also be the issue as well.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
    edited January 2010
    Do you have an Optical cable from the box to the receiver ? Or are you useing HDMI ?
  • WesKParker
    WesKParker Posts: 43
    edited January 2010
    You may have an issue where either you have the inputs from the cable box plugged in incorrectly, or you may have your speakers wired incorrectly.
    The first thing you should do is the test tone from the receiver. It should provide white noise one channel at a time and tell you which speaker should be making the noise at that time.
  • joeygrand3
    edited January 2010
    Tony B
    I am using an HDMI cable between the cable box and the TV.
    Joe
