Sub has a Signal Sensing ON/OFF
IndiansFan
I have my old Yamaha sub hooked directly up to my Denon AVR-884.
from Yamaha's description "...For convenience, the Yamaha YST-SW40 has a signal sensing circuit. When the subwoofer detects an audio signal, it turns its power on. When it senses no signal for several minutes, it shuts itself off."
Have I done something wrong with the hookup in that it always shuts down after several minutes?
Is there someway to override the system so that it is always on?
Thanks,
IndiansFan
Thanks,
IndiansFan
Indians Fan
TV: 32" JVC D Series
AVR: Denon AVR-884
DVD: Toshiba SD 4800
Turntable: Lenco B55
Frt: Polk RTi8
Ctr: Polk CSi3
Rear: Polk FXi3
Sub: Yamaha YST SW40
Nintendo Wii
AVR: Denon AVR-884
Frt: Polk RTi8
Ctr: Polk CSi3
Rear: Polk FXi3
Nintendo Wii
Post edited by IndiansFan on
Unless it has a switch to be able to select between different modes, I would say there is nothing you could do about it. Is there a reason why you always want it on? If it is being used it should be on, and when it's not being used it will be off, this is normal operation for a sub.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
The issue is very likely caused by an insufficient signal below the crossover frequency for however long the subwoofer will stay on before it shuts off.
I used to have a cheap BSR amplified subwoofer (intended for use with small compact stereos or boombox type stereos with detachable speakers) that did just that. If there wasn't a low enough bass signal (common with radio commercials that are mostly just voice, or soft passages of classical music that don't have low brass sounds), the amplifier would switch off and then when the bass signal came back on, the first bass hit also had and audible pop sound as the amplifier suddenly powered back on. -
Mon40CSMM10 wrote: »The issue is very likely caused by an insufficient signal below the crossover frequency for however long the subwoofer will stay on before it shuts off.
Very good point, I forgot to mention that. Had a very similar issue with my old Onkyo HTIB sub.
-JeffHT Rig
Blu-Ray- 80 GB PS3
Thanks. The sub is the last item to replace. It usually cuts out when I have a CD playing. I intend to replace it with the SVS PC12-NDS in several weeks.Indians Fan
AVR: Denon AVR-884
Frt: Polk RTi8
Ctr: Polk CSi3
Rear: Polk FXi3
Nintendo Wii
