FXi A6 & A4 able to mount with bolt on stand???
kevindef
kevindef Posts: 20
edited January 2010 in Speakers
Does anyone know if either or both the FXi A6 and A4 can be bolted to a speaker stand???? I have ordered a set of A4's and a Sanus 30" speaker stand for them. I know the Sanus comes with a bolt and a hole so you can secure speakers to the stand. So does the A4 and/or A6 have a spot on the bottom of the speaker for this???? Thanks!
RTi A7 (Front L&R), CSi A6 (Center), FXi A4 (L&R Surround), RTi A1 (L&R Rear Surround), DSW Pro 600, SDA 1C Monitor 10B
Post edited by kevindef on
  • jdwmap
    jdwmap Posts: 116
    edited January 2010
    I don't believe so, at least on the A6 it is smooth on the bottom. The bracket/mounting plate is actually on the back towards the top. Look at Figure 3 on page 9 of the manual (for the A6, I believe the A4 is the same design). You can see the manuals on the product pages.
  • kevindef
    kevindef Posts: 20
    edited January 2010
    Thanks for the info. I did look at the manual and only saw the wall mounting bracket. I would like to use 2 side surrounds on stands if possible. 1 of the speakers would be in a traffic area, so it would be nice to secure it. There is also the possibility I could mount them on the wall. Thanks for the help!
