Glue for SDA foam wafer
cnh
I did a search on this but I just wanted to double check with the experts.
And I won't be doing this till I get back in July in any case...but one always pauses to think about audio things.
My SDA-2Bs were showing some signs of the foam wafer that is attached to the rubber membrane on the passive radiator...slowly detaching at the edges!
To reattach this, I've read Elmer's Glue and craft Styrofoam glue would be OK..the question is HOW...since it takes 'time' for this glue to dry? How do you keep the wafer FLUSH with the rubber membrane for an hour or more?
Thanks!
cnh
Thanks!
cnh
Post edited by cnh on
Easy, you hold it for an hour...
Come on now, how much do you love this hobby? -
Thats what I did on mine using Styrofoam glue but I let sit overnight just to be sureSpeakers: SDA-1C (most all the goodies)
I've seen guys use a battery connected to the leads on powered woofers.... for a PR though, you basically hold it until it dries up, and let it sit for a few hrs.~Matt
My System
Front L/R: Definitive BP10Bs
Surrounds -Polk Audio Monitor 4As
Preamp: B&K Reference 20
CD: Jolida JD100a
L/R Amp: Carver TFM-24
Turntable: Pioneer PL-516 W/ Shure M97xe
TV: Sony 52" XBR9
