New Amp! Carver TFM 35x needs work.
saabracer23
saabracer23 Posts: 43
edited February 2010 in Electronics
Hey all, I traded my dad my yamaha receiver for his carver amp since he wants to try a surround setup and I like two channel listening. Plus I wanted something alot more powerful for my SDA 2's. Well I ended up with his Carver TFM 35x. Cosmetically it's beautiful. Sonically not so much, only one channel works. We knew this going into the trade and he wants to help me with fixing it.
His suggestion is spending $200 to have Carver completely go over and rebuild the amp (fix anything wrong with it), bring it to their current standards, plus supposedly it gets signed by Bob Carver. I know the signature lowers the harmonic distortion and adds a few watts of juice, but I thought I would get some ideas from you guys.
Is there anywhere else that you know of to send it? I would like to keep it around the $200 mark, a little more if necessary. Is there anyone that will do what carver does, plus be open to mods to make it in ways better?
Any suggestion is helpful!
Thanks,
Dan
Post edited by saabracer23 on
    F1nut Posts: 51,786
    edited January 2010
    FYI....Rita's flat rate is now $350.00. Rolland at Hi-Tech Audio (http://www.carveraudiorepair.com) is about $300.00.
  • thsmith
    thsmith Posts: 6,082
    edited January 2010
    What Jesse said. Either would serve you and your amp well.
  • saabracer23
    edited January 2010
    Thanks guys, I decided to go with Rolland at Hi tech since he lives about a half hour from me. So for $300 he will completely rebuild the amp (replace all of the caps and resistors), bring it to factory spec, and right now he is having a special. Whoever has the complete rebuild done, he will do the bypass mod for free. Is this the negative feedback mod? What does this mod do exactly?
    Dan
    F1nut Posts: 51,786
    edited January 2010
    If you don't know what the tech is doing, ask him to explain it. It may not be something you want to have done.
  • saabracer23
    edited January 2010
    I did ask, but over a short conversation over the phone I didn't really get it. I know there are people on this forum who have had mods done to their Carver amp by Rolland so I was just hoping they could chime in and let me know.
    Dan
    F1nut Posts: 51,786
    edited January 2010
    Oki doki then....
    Bypassing means that he's going to parallel small value, high quality film caps to the exsisting electrolytic types, which should add a bit of speed to the pace. It is not a negative feedback mod.
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    Jesse,
    What would be the advantage to that mod be? I am tempted to have my TFM35x rebuilt but I fear I would never recoup my initial investment plus the rebuild. Plus, I would still just have a mid-fi amp when what I really want is something special.
    Thoughts?
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
    F1nut Posts: 51,786
    edited January 2010
    Kevin, as stated it should add a bit of speed to the pace.
    You won't. One should not look at audio gear as an investment, it's not and one never gets their money back from mods. Mods should be done with one goal in mind, better sound.
  • megasat16
    megasat16 Posts: 3,521
    edited January 2010
    Jacking up the price to $350 isn't going to help Rita shop to be in biz for long.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
    F1nut Posts: 51,786
    edited January 2010
    Had anything fixed in an audio repair shop lately? $350.00 is cheap.
  • thsmith
    edited January 2010
    What Jesse said. I just sold a Caver TFM-45 that was serviced and modded by Rolland. I had over $900 in it and sold it for $600.
    Thats just the price to play, learn and move up.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited January 2010
    Yup - factor in parts, time on the unit, a fair markup to make a fair profit for the service being done. Hourly wage for a good tech is not cheap - figure an average upgrade takes several hours to upack, inspect current state, do the modification, test/burn in the unit, then pack it all back up....time adds up.
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    Yeah... and so the search continues.
    I never look at audio gear as an investment per se. But I never really intended to keep the TFM35x for long term. I have been relatively happy with it's performance, but I know there is another place I want to be. From your sparse comments, I don't think a rebuilt/modded 35 will take me there. ;)
    The money I have in it now will be easy to recoup, and someone else will be very happy to have it when I send it down the road. If they choose, they can rebuild it and still come out "ok" if it's their end-of-the line amp.
    Blah... I answered my own question. Eesh.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • megasat16
    edited January 2010
    I haven't got anything fixed by a service tech for a very long time since i can do mostly myself if I want to and I usually do it myself. I just don't like fixing the thing that requires attention. I like to fix things that will likely need service in the near future and also replaces some parts with better parts (mod). It's the advantages of able to DIY but not many people have time or resources to do that.
    Regarding the wages and the fairness of what the tech charges, I think I agree it's fairly substantial but worth every penny. A competent tech deserves a good hourly salary and it's not an easy job knowing what to do.
    But then, there are reasons of economic. Some carver Amps can be bought for less than the repairs and it's why I think Rita shop aren't going to be in biz for long unless the value of the Vintage Carver amps going up considerable and people will pay more for them on places like eBay and Agon.
    heiney9 Posts: 25,440
    edited January 2010
    I have to agree. It may not be cheap but it's not out of line at all!!! I paid $105 to have a small soft start cap replaced in a pre-amp and there was a lot less work/time involved than I would guess Rita & Co. would do.
    Electronic repairs from a knowledgeable, professional repair shop are not cheap.
  • saabracer23
    edited January 2010
    Thanks for the reply, I traded the amp for a receiver that I could have gotten 100 bucks for and now for 300 I'll have a "like new" amp with the chassis rebuild. I plan on keeping this amp for a long time so it's all good. If the mod upgrades the sound then I guess I'm in. I saw that thsmith had the negative feed mod done to his tfm 45, what would that do for my amp. Sorry for all of the q's but I would just like to get the stuff done while it's opened up. Was it worth it thsmith?
    Dan
    pitdogg2 Posts: 27,057
    edited January 2010
    I agree completely and both of these people know these amps inside and out VERY WELL. I know another person who sent it to a local tech that told them he could do it cheaper and all amp's he's ever worked on were basically the same. Well the dude found out he should of just sent it to Rita or Roland because the cheaper tech FOULED it up so bad Roland told him it was now a parts carcus.
  • thsmith
    edited January 2010
    Dan
    All I know is it sounded great. If it is free then do it.
  • saabracer23
    edited January 2010
    thsmith wrote: »
    So to your understanding, was the bypass mod the negative feedback mod? Reason I ask is because I noticed in your for sale thread that you said you had the negative feedback mod done and on the invoice you posted all I saw was a bypass mod.
    One last question, what was the other mod you did, the IEC mod? What is that for?
    Dan
  • thsmith
    edited January 2010
    Dan
    Whatever the receipt says was done and yes I had the IEC connector installed. It allows you to use a different and upgraded power cable.
    Just give Rolland your money, he will take good care of you.:D
  • snow
    snow Posts: 4,358
    edited January 2010
    Agreed that a flat $350.00 fee isnt a lot when you consider parts also. My tech charges a $75.00 per hour fee to repair things which IMHO is very reasonable, there isnt a reputable auto repair shop in town here that charges less than a $100.00 per hr and most are over that by $20.00 more at least.
    Simplex Grinell which does most of the service work on fire panels on the buildings I take care of charges $150.00 per hr and there are many other companies that charge that or more.
    Even at $75.00 per hr for my tech to break even on a flat fee of $350.00 he would have to diassemble the amp, troubleshoot it, replace the parts, and test everything to make sure it's stable within a 4 hr time period with $50.00 for parts. Thats not a lot of time.
    He tells people all the time its not worth fixing their unit because when he's done the repairs will be more than you could buy something new.
    Of course you can always take the risk that a 15-20 year old amp will work for years to come without repair on ebay for $350.00 also.
    REGARDS SNOW
  • Condodewd
    Condodewd Posts: 1
    edited January 2010
    It's a kick **** little amp. I just picked one up today with the PCT-6 Pre-Amp at a ST Vincent De Paul for 75.00 and all woks great but if I had to spend 250 - 300 I would
    NEWBIE
  • Krazyz1
    Krazyz1 Posts: 256
    + 1 for Rolland @ Hi-Tech Audio
  • cincycat13
    cincycat13 Posts: 888
    +1 for thsmith going to glass ... (happy owner of a modded TFM-45)
