matching RM7 center with R300 and R150
hi!
would an RM7 center speaker match with R300 fronts and R150 surround?
i know the CSR is the matching speaker but i have no where else to put the speaker except in front of the TV, and the CSR would block the lower portion of the screen. but the RM7 would fit in quite nicely
if i'd stick with the CSR, my only other option is to stick the speakers into the cabinet and put it on top of my DVR. but would it be safe to do so? wouldn't it mess with the hard disk in the DVR? and even if the hdd is safe, the speaker would block the vents on top of the DVR, so this is probably not an option
any suggestions?
any suggestions?
Post edited by choy on
from your previous post, if their is no way to raise the tv on its stand, your limiting yourself to the RM7, dont expect a whole lot and you wont be disappointed.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
yeah, i never considered how big the speakers would be until after i bought the TV and stand. i did some measurements and the only logical place to put a center speaker the size of the CSR is behind the TV on a wall-mounted bookshelf. then again, it wouldn't be ideal as the speaker would be behind the TV and the two tower speakers
i don't know how much to expect, i'm still a bit of a newb. plus the setup is pretty low-budget, entry-level to begin with
