My 1C's FINALLY
Pycroft
Hi all...
Here are some pics with my 1C's...cosmetically, not good shape...they sound fantastic though Setup is in my signature. Any way to touch up the cabinets? I will post later, when I have more time, their position in the room so people can hopefully comment on the setup. Rug is being installed on Saturday, so I'll have a nicer setup then.
James
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
Excellent . . . when do the inevitable upgrades start?:D
More pictures:2 Channel/HT:
Harman Kardon HK354
Sony SACD Player -
As you can see...the fronts look very nice...the tops and sides, and even the back are scratched, or worse. The bottom, the cork underneath is in bad shape also. Will probably put them on some granite...perhaps hack off the bottom cork? Woudl love to hear comments ... and no upgrades as of now ... I like how they sound!2 Channel/HT:
Harman Kardon HK354
Sony SACD Player -
nice! They look like they could use a refinish, otherwise nice looking speakers.~Matt
My System
Front L/R: Definitive BP10Bs
Surrounds -Polk Audio Monitor 4As
Preamp: B&K Reference 20
CD: Jolida JD100a
L/R Amp: Carver TFM-24
Turntable: Pioneer PL-516 W/ Shure M97xe
TV: Sony 52" XBR9 -
Isn't there a law in New Jersey to prevent that kind of abuse to a fine set of speakers? If not there should be. Well thank God they sound good still. Congrats.
KelvinSDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
I bought them from someone in PA...I guess there are no laws there How do I refinish speakers? I don't believe these are real wood...they are 1C studio versions.2 Channel/HT:
Harman Kardon HK354
Sony SACD Player -
Yes those are studios. Touch up with a sharpie or some black touch up paint if it bothers you.
If you know someone with a Harley that uses a product call Pig Spit, give them a good wipe down and you will be shocked at how much blacker and deeper the black will look.
What do you mean by Cork ? I had 1C studios and no of no cork on them.Speakers: SDA-1C (most all the goodies)
Spike those bad boys . . . you won't believe the improvement in bass and imaging.
https://myesound.com/Points_n_pads.html -
You'll be bowled over after you do the crossovers, upgrade the tweeter, and Dynamat the midwoofers and passive radiators. You think they sound good now . . . you ain't heard notin' yet! -
I was going so suggest a sharpie touch up job too. Pig Spit is good stuff.
Nice score Pycroft.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
Conradicles had in his 'system showcase' 1C's, and he said they got a custom paint-job by someone. They don't even look like the same cabinets. I think they look fantastic. Anyone know how to do that. To be honest, it's not super important, because they're in the basement, where my 'man' area is, not in a living room or something, but it would still be nice to have them look respectable.
Cork isn't the right word. This is a copy/paste job from another user in a thread on 1C's: "Quote:
My idea for the base of the 1C Studio was to remove off the square base and replace it with two pieces of flat 3/4" MDF that are sandwiched together (glued and screwed). Round the corners and bottom edges a bit, then Primer and spray pain them black, then screw to the bottom of the cabinet and mount the spikes into the new base".
It's a rather thin base that goes around the bottom of the speaker, but is thin. I will take a picture of it. Another user removed his and put it on granite (Want to try this, perhaps without removing the actual base).
Thanks for the comments, keep em coming2 Channel/HT:
Harman Kardon HK354
Sony SACD Player -
The cabinets are the same the outside shell anyway. 1 has the risers like yours the other has the caps top and bottom with the grill cloth on the sides. the main cabinet for the drivers and tweeters are the same though.Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
Here would be my suggestions to you based on the other SDA's I have seen refinished by other polkies on this site:
You could...
Just apply new black vinyl veneer to the tops and sides. It is easier than you think and not too expensive.
Nikolas812 painted my top and bottom caps, but it was not cheap. He does a fantastic job.
Enjoy and keep us updated. -
1st try the Pig Spit, you may be suprised.
I bought some Klipsch KG2's a couple months ago that were black and scratched up a little. With something similar to the Pig Spit, they looked very nice. I was shocked! -
One more thing James...take your time on them. I did mine in steps so I did not have to shell out all the cash at once.
Don't get me wrong, if you have the money by all means go all out! -
I am supprised others have tried Pig Spit. I mentioned it over a year ago and got various comments but none where people have used it.Speakers: SDA-1C (most all the goodies)
Awesome score! can't wait to see the upgrades when they happen.
Enjoy! -
Nice info, one question to all- What are the final spec ratings for SDA-1C's? I have literature that says they are 10-750W per channel and others that list them as 50-500W. I understand they fall into the 6 ohm rating and the studio and wood versions are the same speaker inside. Just really curious
.......a product call Pig Spit, give them a good wipe down and you will be shocked at how much blacker and deeper the black will look.
okay, so what exactly is "Pig Spit" and were do you buy it? Stain, paint? Both? Other? Sounds like a great 'restoration aide' for black speakers. Any long term detrimental effects?
Just found it....didn't actually think it would be called"PigSpit" but yep it is....lol
(you know like q-tip or band aid, is a generic term now)
http://www.pigspit.com/
do you recommend 'Fast detail' or 'Original'? -
http://lmgtfy.com/?q=pig+spit"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Perhaps this will give you some details. Really doesn't matter unless you're running a 5 wpc flea amp.
This weekend I'll be hooking my 1C's up to my 15wpc 6V6 based tube integrated. I have no doubt it won't be an issue. I'm sure it won't win an SPL contests but who cares.
http://www.polksda.com/sda1creview.shtml
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Interesting! Thanks for the link H9
Orignal is the only I have ever used. Not for wood but vinyl and such material.Speakers: SDA-1C (most all the goodies)
So Heiney....
How do your SDA 1Cs sound with your 6V6 based tube amp?
Enquiring minds need to know.
Thanks,
WayneYamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
The best thing I've found for black vinyl cabs is plain old black shoe polish. the stuff will work wonders on scratched cabs.Denon PMA-900V
Linn Axis with Grado Red
Cambridge Azur 650C
Polk SDA-1BTL
