5.1 vs 7.1 Setup??
reubenray
reubenray Posts: 91
edited January 2010 in Speakers
I am debating on setting up a 7.1 system in my permanent home or not. I will be using the FXi3 and FXi4 speakers for the rear and side surrounds. My concern is the space between the side surrounds and the rear surrounds will only be 4'. This is using the Dolby setup where the back surrounds are in the corners. Now if I use the THX setup (which shows the back surrounds being together and in the center of the room) the speakers will be further apart.
So will setting up a 7.1 system be worth it or not?
Onkyo TX-NR709 A/V Receiver
Polk RTi8's Front
In-Walls for Rears
CSi5 Center
SVS 20-39PCI Subwoofer
Post edited by reubenray on
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited January 2010
    If you have the speakers, try it out and make the judgment call yourself. Your ears, not ours.
    That said, as a general rule of thumb, a better positioned/calibrated 5.1 system WILL SOUND BETTER than a poorly positioned/calibrated 7.1, factor in that most movies still don't have 7.1 tracks (so you're dealing with matrixing... which still can sound pretty damn awesome mind you), and you have a situation where 7.1 MAY not be the best.
    If you'd like, post some pictures of your set up, including listening position, or perhaps draw up a quick floorplan with distances. Doing so will help immeasurably when determining if 7.1 will work for you.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited January 2010
    Theatrical movies will never have 7.1 tracks, because they aren't necessary for the theatrical space. 7.1 exists primarily to achieve in the home what 5.1+EX achieves in the theater.
    In my setup, I split the difference between the THX and Dolby placements, and I'm pretty happy with it. I also pulled the side surrounds very slightly forward of the listening position (using direct radiators, not dipoles), which most people will tell you is a no-no, but given the dispersion of my speakers, doing so gave me outstanding sidewall imaging and very precise panning around the room.
    If you're using the FXiA4s on the back wall, change them to BIPOLE first. If you can place them strictly per Dolby's angles, do so and use DPL-IIx Movie to handle the matrix processing. Also, you might try running your side surrounds as bipoles once you have the rears in play, since you no longer need the dispersion of dipoles once you have a 4-speaker array handling the surrounds.
    Ultimately, it'll all be about how it sounds to you though. Good luck!
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • reubenray
    reubenray Posts: 91
    edited January 2010
    I have been looking for a free program that would let me draw up my floorplan, but have not found one yet.
    Polk RTi8's Front
    In-Walls for Rears
    CSi5 Center
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2010
    reubenray wrote: »
    Placement guides aside, my most important factor to 7.1 is room size. If your room won't support it, then a properly setup 5.1 will outperform a cramped up 7.1 anyday.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
    edited January 2010
    +1,
    But there are some people here that 'think' their living room is the size of an iMax theater. They have a half dozen subs in there--and even in their walls and floors, arrays of sides--rears--and even ceiling speakers, the latest 9.2 AVRs...and it's still not ENOUGH.
    My advice! You want iMAX go buy a ticket or else your wife, if she has any sense, should divorce you! There are hobbies and then there are OBSESSIONS!!!
    Intoxia Surroundus!! The opposite of anorexia for audiophiles.
    cnh
  • wutadumsn23
    edited January 2010
    cnh wrote: »
    +1,
    Intoxia Surroundus!! The opposite of aneroxia for audiophiles.
    cnh
    LOL, I am with you on this one. 5.1 is plenty in a normal sized room, for both you and your wallet, lol.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • Knucklehead
    Knucklehead Posts: 3,602
    edited January 2010
    cnh wrote: »
    Thats some funny stuff....:D
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • kuntasensei
    edited January 2010
    cnh wrote: »
    +1,
    cnh
    Jeez... now I feel kinda' guilty for having 9.1. :D
    Equipment list:
    Emotiva XPA-3 amp
  • wutadumsn23
    edited January 2010
    LOL, to each his own. If my room could handle it I'd have 11.2 or 11.4, lol. If you have a big room, then you need more speakers to fill it up, I think cnh would agree. Just seems like everybody these days is jumping on the 7.1 (or higher) bandwagon cramming speakers in every nook and cranny in the rooms, when 5.1 would be just fine.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
    edited January 2010
    +1,
    Ever hear the Bass in a great iMAX set up! INCREDIBLE! Could probably tear your house apart! Speaker arrays 'everywhere'...pretty impressive.
    cnh
  • kuntasensei
    edited January 2010
    -Jeff
    Yeah, my room's like 12'x18'. :p
    Equipment list:
    Emotiva XPA-3 amp
  • concealer404
    concealer404 Posts: 7,440
    edited January 2010
    Hahhahaa holy crap. I have a 12x16 room and i'm having a hard time fitting a decent 5.1 setup.
  • kuntasensei
    edited January 2010
    Yup. And I'm sitting 10' back from a 100" screen in that space using a Sanyo PLV-Z2000 projector, with RTi70 mains, CSi40 center, 4 RTi28 surrounds and Monitor 30 heights, with a SVS 20-39CS+ and Buttkicker. Sure, it doesn't resemble a living room anymore, but it sounds fantastic! :D
    Equipment list:
    Emotiva XPA-3 amp
  • concealer404
    edited January 2010
    You're single, aren't you...... :p
  • kuntasensei
    edited January 2010
    BAH HA HA HA! Yup, you nailed it. :) But when the screen's up, it sort of resembles a living room... with a lot of speakers in it.
    Equipment list:
    Emotiva XPA-3 amp
  • wutadumsn23
    edited January 2010
    LOL, damn. Reminds me of that commercial where that guy is sitting like 2 feet from his speakers in that chair and his scarf/tie is flapping behind him....... :D
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • kuntasensei
    edited January 2010
    -Jeff
    Yeah, when the SVS gets pumpin', it's a little like that. :D
    But... 9.1 is NICE!
    Equipment list:
    Emotiva XPA-3 amp
  • concealer404
    edited January 2010
  • wutadumsn23
    edited January 2010
    LOL, That's the one!! ^^ kuntasensei^^ Thanks concealer.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • kuntasensei
    edited January 2010
    BAH HA HA HA! Photoshop in a couple of RTi70s and a SVS sub and you'll pretty much have it.
    Equipment list:
    Emotiva XPA-3 amp
  • wutadumsn23
    edited January 2010
    That is hilarious, I can actually see you sitting there and that happening to you. One of the funniest things I have seen in awhile.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2010
    7.2 rocks the RTT.
    RT1
  • kuntasensei
    edited January 2010
    -Jeff
    I hit 109dB during The Haunting DTS once... and it pretty much felt like that picture. Heh...
    Equipment list:
    Emotiva XPA-3 amp
  • wutadumsn23
    edited January 2010
    LOL, insane. You are gonna go deaf soon. Must be a rockin system.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • kuntasensei
    edited January 2010
    Don't worry... Those are NOT typical listening levels. I'm usually at around -15dB from reference. But occasionally, you have to throw some material up against your sub and see where its limits are. After that run through of The Haunting, I realized that my SVS might have limits... but they were apparently well beyond where I was willing to turn the volume knob.
    Equipment list:
    Emotiva XPA-3 amp
    edited January 2010
    Everything has 'limits' but the most precious limit is your hearing...you don' want to damage that with constant greater than 85--90db+ sound levels.
    cnh
  • kuntasensei
    edited January 2010
    My law firm handles industrial hearing loss claims. It isn't the low frequencies that kill your hearing anyway. Trust me... I'm good. ;)
    Equipment list:
    Emotiva XPA-3 amp
  • wutadumsn23
    edited January 2010
    Oooooo, Mr. fancy Law guy, lol. Law don't go around here law dog!! My hearing is already crap anyway, just ask my wife. :D
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • kuntasensei
    edited January 2010
    -Jeff
    Yeah, but aren't we all blessed with selective hearing when it comes to women? I guess you can't really pull out your SPL meter and say, "I'm sorry, honey, but your bitching exceeds OSHA standards for safe sound levels in the home... so I'm gonna leave the area of exposure now."
    (Okay, maybe there's a reason I'm still single. :D )
    Equipment list:
    Emotiva XPA-3 amp
