monitor 70 placement?
Dabutcher
Dabutcher Posts: 2,597
edited January 2010 in Speakers
I just purchased four Monitor 70's from Newegg for 179.00 each and want to set them up with basic placement? Currently they are side by side two inches from either side of 73 inch rear projection .Basically four fronts with no rears.I might add some Orb Audios I have for rear when I upgrade reciever from my Sony STR-D 590 which I cannot get the rear channels to work?Thanks
Post edited by Dabutcher on
  • rcpolk
    rcpolk Posts: 22
    edited January 2010
    Hi! How did you get M70's for $179 when NewEgg shows them for $199 each?
    thanks
    Receiver Sony STR HD800
    Center: CS10 Polk
    Front: Monitor 70 Polk
    Sub: PSW 10 Polk
    Sorround : OWM3 Polk
    edited January 2010
    WELCOME TO CLUB POLK!!
    You're using 4 M70s as fronts with a SONY receiver...good luck with that....that AVR won't last too long! How big a room do you have and why do you want to run so many towers up front?
    Two should be adequate..but you'll need more power.
    cnh
  • Dabutcher
    edited January 2010
    The m70's were on sale with coupon for $159.99 when I first discovered them.By the time I decided to purchase them they went to 179.99 and I contacted Newegg about the 159.99 price. Then the Newegg raised the price again to 199.99. So since I was already dealing with customer service they sold them to me for 179.99. The way it looks to me is that they will all be out of stock soon? Get them while you can! thanks for the advice.
  • Blacklamb
    Blacklamb Posts: 14
    edited January 2010
    I have my M=70's about 2.5' away, from my 61" rear projector. They are also pointed towards my center chair. As others have said get the CS2 center really brings the whole thing together. If you can get some rears.
  • kcoc321
    kcoc321 Posts: 1,788
    edited January 2010
    better hurry, they only have 88 black & 96 cherry ones left in stock
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2010
    Here is a guide from Dolby for speaker placement. It is a good start, but it is really up to you where they sound their best. Mess around with them and if your AVR has a calibration program (IE Audyssey) give that a shot too. Hope you get it all set up and sounding good.
    -Jeff
    http://www.dolby.com/consumer/setup/speaker-setup-guide/index.html
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
