Jeffrey69
Jeffrey69
Jeffrey69 Posts: 2
edited January 2010 in Speakers
I have a pair of bookshelf Polk Audio all black finish speakers. I got them roughly ten years ago. Power Port, Dynamic Balance featured. My issue is I need speaker covers/grills all black that came with these. No model # on the speaker anywhere and I don't remember the watts, ohms, etc... Cabinet measures 14-7/8"H 8" W 10" D, Woofer is 5-1/2", Tweeter 2-1/2". The woofer and tweeter are mounted in a raised teardrop hard plastic housing with a air hole at the bottom within the housing. The cover peg holes measure from center of hole to edge of cabinet 1-1/4" from top and bottom of cabinet and the center of hole to center of next hole horizontally at 5-9/19". DOES ANYONE KNOW WHAT THE MODEL NUMBER IS OR HOW I CAN GO ABOUT GETTING REPLACEMENT COVERS FOR THE PAIR???
They work perfect but ugly to look at.
Post edited by Jeffrey69 on
    Toolfan66 Posts: 17,351
    edited January 2010
    Sounds like RT35i, but a picture would help..
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited January 2010
    That's my vote too.
    Not sure if Polk still stocks the grilles, highly doubt it. You may have to punt. Custom fabrication or find someone on here willing to part with theirs for a price. Good luck either way.
    Is this it? If so, RT35i.
    EDIT: It's technically a 6.5" woofer; not sure where the 5.5" is coming from.
  • Jeffrey69
    Jeffrey69 Posts: 2
    edited January 2010
    Thank you so much! That is the speaker. Do you have any suggestions on grill kits or custom fabrication companies?
  • rallyshark
    rallyshark Posts: 417
    edited January 2010
    Go to Parts Express. Look in the speaker building section. They have all the grill making accessories you could want:)
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS3(games/media server)
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    When rapture comes, can I have your car?
